thread restorer question
PoorOwner
CA
I have the craftsman kit which is similar to the bluepoint etc.
Anyway I noticed if I put a good bolt or bad bolt it always need a bit of force to run it through, ratchet required. If I use a die from a tap and die kit it doesnt do this. I used oil.
So my question is does the restorer actually cut the bolt slightly smaller?
scissorman
Pleasanton, Ca.
A tap will cut threads whereas a restorer reconditions the existing threads by forming the threads back into shape. The short answer to your question is NO, a restorer will not cut the bolt smaller.
dodge610
North Canton Ohio
Restorer should just clean up and straighten the thread. Tap and die should cut new thread. I do not think the restorer does much cutting.
P
PoorOwner
CA
I am very puzzled with it then, when doesnt the bolt thread in without resistance. I am sure that is the thread. even bought a new die to make sure.
I do see a few speckles of metal if I run it through
Fcvapor05
The short answer is that most thread restorers are made to form to the tightest end of the tolerance window for a given fastener size, so that one restorer is good for all fasteners of that class.
For example, a 1/2-13 restorer will form the threads to 3A (or 3B). If you run it down or through a 3A/3B fastener, you will get a little resistance, but not a ton because the fastener is made to the same tight tolerance as the restorer. If you run the same restorer down a 1A/1B fastener, you'll likely get a lot of resistance because the restorer is made to 3A/3B but the fastner has much looser tolerances.
Most hardware store bolts aren't going to be 3A/3B, so most of the time it's going to take some effort to run the restorer down.
Finky198
North East
As said above this is for taps and dies but it's a great visual
