Thread sealant
johninct
I am doing a water pump and need a thread sealant for the bolts that go into the antifreeze. Anything special to use? I was going to use Gasolia or some other pipe thread sealants I have around. Thanks.
428PI
Peabody, KS
Teflon paste. Not had a problem with this sort of thing despite what LS6 Tommy says. I've been a mechanic for over 40 years.
LS6 Tommy
Northern NJ
Sounds like the guy that has had PVC air lines for 40 years without a problem. :lol_hitti
Seriously, do it however you see fit. I'm just providing info... :beer:
Tommy
Tinkerman66
Just FYI, TFE Paste is not a sealant. It's a lubricant and it's not designed to be used for machine threads like water pump bolts, it's only for mating pipe threads.
Tommy
"It's only used for mating pipe threads"
To seal them, no?
rlitman
Long Island
Tommy
There are all sorts of teflon pastes. Ones meant for mating pipe threads are indeed thread sealants for NPT type conical tapering threads (they're non-curing sealants that are not meant to fill the large gaps of parallel threads).
Now about your water pump bolts. Those don't have conical tapering threads. Also the threads don't form the seal. So no amount of any sort of paste on the threads will help with the seal. Be it teflon paste, or form-a-gasket (which I don't like on threads), etc.
Either the threaded hole is blind tapped and doesn't open into the water jacket, or there should be a sealing washer under the bolt head, or perhaps the blind hole is under an ear that projects outside of the gasket's sealing area in which case nothing is wet.
I like to use a teflon paste pipe dope on the wetted threads anyway, as it prevents seizing, and is less likely to wash out than a metallic anti-seize (which I would use on the dry threads in the third case I mentioned). Plus you shouldn't be introducing foreign metals (metallic anti-seize) into the antifreeze anyway.
Falcon67
Merkel, TX
Not a damn thing here. I used stainless bolts, no sealant. If I was to use a sealant, I'd lean to Permatex #2.
redmondjp
Redmond, WA
I thoroughly degrease and dry the threads on both sides and apply a bit of Permatex Ultra-Gray RTV to the threads before installation - only on those bolt holes that go directly into coolant passages. On ones that go into engine oil, I use Permatex #2.
LS6 Tommy
Northern NJ
To seal them, no?
Actually, straight PTFE pastes and tapes are not sealants at all. Most "pipe dopes" are not. They are lubricants that allow a proper interference fit on tapered (pipe) threads. There are pipe thread sealants that contain PTFE, so it can be confusing.
Permatex #3 Aviation form-a-gasket is specifically listed for use on "screw threads" like water pump, intake manifold or cylinder head bolts as a sealant and is approved as such for both automotive and aviation use.
:thumbup:
Tommy
clubairth
Another internet expert.
Perhaps reading a label might point to the correct answer?
Yes it's a sealant.
