drewvdw
Hi all, I've got a problem, I was going to get started replacing the timing belt in my Subaru, but some of the bolts have spun the threaded inserts they are bolted in to. Obviously the inner plastic cover will need to be replaced ($30 from the dealership, no biggie) but I need to save the outer cover which is rather expensive (why, I don't know, they're both about the same size). I don't really have access to the back of all of the bolts, I was thinking of using some vise grips or pliers or something to crush the plastic around the inserts, but I can't get to them. I can't grind the heads off the bolts because I'll melt the plastic timing cover. I don't have room for a drill (even my right angle drill is too large without a drill bit). Have you guys got any ideas? Or am I kinda SOL? If I have to order the outer timing cover too, I'll do it, I just really don't want to. I'm already spending way too much on it.
Thanks guys!
Thanks guys!
