Threading questions
LarryFahn
I'm familiar with tapping, but what's it called when using a die? Dieing? Tapping? Or just threading? Curious...
Second, what's the way you're supposed to thread a rod with a die? Aligning it is nearly impossible. I do have access to a small lathe and Bridgeport. I'm trying to thread the outside of a 6mm rod with an M6 x 1.0 die. I was considering on turning the OD down to the minor diameter of the M6 thread and leaving it about a 1/4" for the die to rest on so alignment wasn't an issue. Any other ways? Let me know. Thanks
paulsomlo
Northern Colorado
It also depends on the die you're using - if it's the standard non adjustable hex die, you're going to have a tough time, as they're best suited for rethreading.
alfadan
Augusta, ks
If you don't want to spend the dough on a die holder for the tailstock, you can just push up against the die with the quill. You need three hands to keep feeding the quill and turning the diestock, but it'll get you started straight.
DGersic
DeKalb, IL
I’ve always just called it threading, or cutting threads.
I don’t have a lathe. I just chamfer the end, and hold the die straight while getting it started.
L
LarryFahn
This is kinda what I did. I chucked on the material and locked the spindle. We have a jacobsen chuck in the tailstock. I put a bolt in the tail/chuck to push flat on the die. Turning the small die handle with one hand and the tailstock wheel with the other for the first thread or two. It worked out good.
Thanks for the advice everyone.
