Above 1200 Sq/FT Three Decades, Four Garages, One '77 C10
mapesken
The Woods of NE Florida
The floor is well underway.
Another GJ member and my wife assisted in moving everything outside.
Where we started
Going
Gone
Shot blasting was fun with a stopped up vacuum and a wounded shop blaster.
Every time I get rental equipment from the green place I end up working on it. Before it works "As intended"
Vacuum filters the third one was the worst it had a rag sucked into it. Sorry no pic. I was covered in dust and not taking pics.
The shot blaster had sintered the shot onto the control collar part 3 and the impeller part 7 at first restricting the flow of shot and ultimately stopping it completely.
That led to an exhilarating romp disassembling things I had never seen before...
20260801_022221.jpg I found the manual online...
Utilizing my mechanic skills I removed this from the unit with a hammer and a center punch. Without breaking the control collar.
20260801_215337.jpg Quarter for scale.
The control collar is also how the shot is "timed" to adjust the pattern.
The collar was 90 degrees "retarded" resulting in the heavy right side pattern seen in the pics.
Once the collar was "advanced" the pattern was even.
My wife ran the blaster and I was shot wrangler/hopper filler.
We used 50 pounds of shot to blast 1600 square feet.
Originally I was told it required 50 pounds per 250 square feet or 320 pounds.
I got 3 glad they will take the 2 back I didn't open and even happier I didn't get 6 as suggested.
Thanks RMACK898 for the good advice and help.
mapesken
well the shop floor is blasted
I returned the rental items.
I handed the manager the zip-lock bag full of melted shot. (see previous post)
He acted shocked as I explained the issues with the equipment.
But was most likely glad I was not screaming at him about the situation.
He explained they are supposed to test the equipment before it is sent out.
He gladly refunded the cost of the unused shot and took $50 off the rental fee.
The tech that repairs the equipment asked if everything was OK.
I told him the equipment performed less than optimally and the manger handed him the bag of melted shot.
He was bewildered.
I was stressed about the working time to apply the primer, the measuring and mixing process with sticky uncured product all over everything was not helping the situation either.
Spreading 4 gallons and back-rolling 800 square feet in 12 minutes!
Wife and I did manage to get the primer onto the concrete and it looks good.
Tomorrow color and flakes then topcoat.
mapesken
The floor epoxy was very stressful. The advertised working time was way shorter than advertised.
3 gallons of color and 20 lbs of Domino flakes
Another 3 gallons of color and 20 lbs of flakes
Then 3 gallons of UV stable clear
3 gallons was not enough clear which required a 50 minute trip to the Sherwin Williams Industrial coating store and 50 minutes back to the house.
I also stopped by Home Depot to pick up 2 new 18,000 BTU dustless mini-split units.
Screenshot 2026-08-06 at 21-39-29 Costway 19 SEER2 18 000 BTU 1.5 Ton Ductless Mini Split Air ...png
Wife and I then applied 3 more gallons of clear.
Now we wait...
mapesken
I was outside working this morning when, low and behold, our former house building inspector drove by.
He slammed on his brakes, backed up, and hopped out to chat. He mentioned he was in the neighborhood for a roof inspection around the corner. We ended up reminiscing about the build, and he said he still keeps photos of our home on his phone to show other professionals how a build should actually look.
He couldn't believe it's already been four years since we finished the house and he issued our Certificate of Occupancy.
It was good catching up with Eric.
I told him if all goes well he may be out to inspect the metal building extension.
He said he looked forward to it...
larry4406
Northern Virginia
That’s awesome!
I have had inspectors ask if they can use one of my houses under construction for training.
I tell them sure bring on the *********!
Sure enough 5-10 inspectors show up and wire brush me. It’s all good as the house and my knowledge can only get better.
