I've been messing around with these three phase motors for awhile, I can't seem to leave well enough alone. I use them to run a 5 hp three phase compressor.
I replaced the bearings in the 10 hp motor on the left and painted it. The other is a 7.5 hp, I welded up the frame with some 1/4" angle iron. The motors are wired in parallel and each has a disconnect. I start the 10 hp with a pony motor and the other will self start.
The frame has a little wobble which makes the motors rattle, I guess the motors need to be bolted down to the frame with some rubber as a dampener.
I'll probably disassemble again and use 6 ga. wire, and feed it into a three phase panel I found.
http://s228.photobucket.com/albums/ee137/3CL1/?action=view¤t=RPC121910001.mp4
