cody1325
On a related note--how do I get the handles off **** screwdrivers? Need a few file handles, and that box full of cheap and broken screwdrivers has more than what I need--and file handles have gotten a tad pricey locally.
Vise grips and a pry bar. Clamp down close to the handle and squeez the two together.On a related note--how do I get the handles off **** screwdrivers? Need a few file handles, and that box full of cheap and broken screwdrivers has more than what I need--and file handles have gotten a tad pricey locally.
Last week, I clamped an old screwdriver's steel tightly in a vise. Tapped on the handle with a hammer and a punch made from an old ratchet handle. Took less than a minute to have the desired product in hand.On a related note--how do I get the handles off **** screwdrivers? Need a few file handles, and that box full of cheap and broken screwdrivers has more than what I need--and file handles have gotten a tad pricey locally.
Hey, @NUTTSGT, don't forget to stick a ratchet in there before you might have to use that socket set.
There are good reasons for using cheap tools for a travel kit. But I have the opposite view. The last thing I need is a tool that fails when I am fifty miles from the nearest store or service center. Where you drive will make a difference. Probably not an issue for those near the East or West coast. I often go past a sign that says "No services next 120 miles".
Slip a box end over the shaft and clamp the shaft in a bench vise. Now you can pry it off using the box end to avoid concentrated and damaging force.On a related note--how do I get the handles off **** screwdrivers? Need a few file handles, and that box full of cheap and broken screwdrivers has more than what I need--and file handles have gotten a tad pricey locally.
Daddy?I keep several large worn out screwdrivers handy for opening and stirring paint cans.
YMMV
YMMV
You might be over tightening your chuck.I keep a spot in my toolbox for old tools that I may be able to make something with. Like these cheap impact sockets... That I should have thrown away... but one day I decided I needed to make a couple drill chuck tools. They are 3/8" drive. Now I can use a 3/8" drive ratchet to tighten my drill chucks. So tired of my wrists getting sore. Mission accomplished. Every time I throw away something I "think" I may need... within two weeks... I would have used that. So... The point of the story is.... If you "think" you may use it someday... keep it. If your gut says.. "no" throw it away.
Baling wire from my (now ex) wife hanging it over the top wire of the fence when feeding horses instead of throwing it on the junk pile in the shed. Corkscrewed its way into the bottom of my right calf. ER doc had to make an incision to “unscrew” it from my leg. Had to cut the excess off with what must have been the world’s dullest side cutters because there was so much sticking out of my leg she couldn’t see where it was at on the X-ray. Th side cutters were so dull she was shaking the wire in my leg making it hurt even worse. It finally cut through the wire right before I was gaining to tell her to stop and send the wife up to ACE to get a new pair to donate to the ER.Where they eventually end up embedded in your shin--like silverware in the lawn at the pub when I'm mowing.
Can I be your new friend?I have exactly the opposite problem. I give away basically brand new Milwaukee tools when they release an upgraded version. Just gave away a M12 stubby version 1 when they released the new version 2. Same story with the 7 1/4" circular saw and the left sided 6 1/2" circular saw. When the new ones came out the old ones had to go. For some reason I have to have the latest and greatest and whatever isn't goes out the door. Needless to say my friends love me.
As best I can tell, I haven't worked on anything roadside since 1990. I carry a single 10mm wrench, a screwdriver and some duct tape.I quit carrying tools in the truck ten years ago when I realized I had carried a travel box for ten years prior to that and never had to use any of the tools.
Vehicles are pretty reliable, and have been for fifty years.
How do you get past the guilt of throwing stuff away?
I don't carry tools for the truck. I carry them for whatever trailer I am towing. Or what might be on or in it.I quit carrying tools in the truck ten years ago when I realized I had carried a travel box for ten years prior to that and never had to use any of the tools.
I think the way snap-on does it is they put the driver portion into a vise and they take a wrench of an appropriate size so that it will push on the handle and then they knock it off with a mallet that is softer so it won't damage the wrench. I've seen it done. I've never done it.On a related note--how do I get the handles off **** screwdrivers? Need a few file handles, and that box full of cheap and broken screwdrivers has more than what I need--and file handles have gotten a tad pricey locally.
I often wonder just how many hours I've spent on roadside repair... you need more "interesting" vehicles!I quit carrying tools in the truck ten years ago when I realized I had carried a travel box for ten years prior to that and never had to use any of the tools.
I used to drive through the mountains where there was no cell perception even on the expressways, I assume they have it now but they surely didn't back then.I'm often driving around where there is no cell reception and often very little traffic--if it breaks, it's up to me---or a very long hike.
Yeah I have a usa Stanley slotted screwdriver with a buggered tip and bent shaft that my go to pry tool.Or repurpose it.
I have everything from a 36 Ford pickup to eighties and nineties Mustangs to Super Duties that are25 years old to a couple of six month and 14 month old Mavericks, and more.I often wonder just how many hours I've spent on roadside repair... you need more "interesting" vehicles!
My "carry" box has gotten much smaller over the years as I realize just exactly what I need for a particular vehicle--and I no longer work on any rig but my own.
I did carry one of those "emergency" CB radios back when I was working in the woods. Better than smoke signals, I guess. Loggers and trucker still use CB out here.I used to drive through the mountains where there was no cell perception even on the expressways, I assume they have it now but they surely didn't back then.
I have a ham radio license and I had a radio in the car, specifically 2 m and 70 cm. One time there was a very large car. Pileup and I was able to reach out to people that were 30 miles away and they called in emergency services.
Some repeaters but even have phone patches but usually you needed to be a member to use it.
You don't need a very high license to be able to use a 2 m radio with a decent amplifier that will really reach out. Then again, if you're down on a gully that probably won't help. And unless they have repeater set up that you're able to hit, you need to have someone listening.
Lot of the guys listening are retired and helping ing motorists is probably the highlight of their day. Long before GPS's were a thing I had to get in someplace and I didn't have an app and it was very convoluted. They had guys with maps spread out on tables talking me through things turn by turn. The GPS and cell phones with internet on them have really changed things.
I suppose you fix things before they break?I have everything from a 36 Ford pickup to eighties and nineties Mustangs to Super Duties that are25 years old to a couple of six month and 14 month old Mavericks, and more.
The last time I recall breaking down was in 1970 when I ran out of gas on the bridge in my 55 Chevy, and then again when the same car broke a pinion tooth in front of mt then girlfriend’s, now wife’s house later that same summer.
Got towed to an OReilly’s and bought a new belt and a 15mm impact socket to use on the tensioner.
