Thunderbiscuit's Tools
Status
Not open for further replies.
Thunderbisciut
Cape Cod
Cape Cod
Price
Varies
So I have some Zephyr Industrial bits sitting here waiting for a new home. These are extremely high quality, and not so easy to get. These are heat treated in small lots, and when I get them in the lot number is included in each. I found this to be pretty unique from other companies.
All of the bits that I'm offering are 1/4" hex, and their "Industrial" line, which are the hardest they offer. Because of that these probably aren't suited for impact drivers.
This is how the pricing will work, the price listed next to each piece includes shipping. If you purchase more than one bit you will be discounted $.50 for each additional bit you buy. The formula would be: Discount = .50(number of bits - 1).
In other words, if bits were $2 each, and you bought 2 of them, the total would be $3.50. If you bought 4 $2 bits, the total would be $6.50.
OK, with that nonsense out of the way, onto the goods.
Philips ACR bits:
P1, P2, P3 - $1.50 each
Philips bits:
P4 - $2.50 each
Pozidriv ACR bits:
PZ1, PZ2, PZ3 - $1.75 each
Slotted bits:
.034x.170, .046x.261 - $1.75 each
Square bits:
S0, S1, S3 - $1.50 each
Torx Tamper Resistant bits:
T7T - $3.25
Torx bits:
T5, T6, T7, T9 - $2.25
T10, T20, T25, T27, T30, T40 - $2.00
T
Thunderbisciut
Cape Cod
Cambell Hausfeld 3/8" Air Ratchet Used
Very good shape, the usual scratches and whatnot, but in perfect working order. I don't know the torque specs, but it's weaker than my 50lb Chicago Pneumatic, and stronger than my 15lb Chicago Pneumatic.
T
Thunderbisciut
Cape Cod
4 Proto SAE Nutdrivers, Used
These are used, 2 are in very good shape, 1 has the handle slightly scuffed up, one has the handle slightly more scuffed up. The models ending with "H" are hallow shaft.
9208 - 1/4"
9210H - 5/16"
9212H - 3/8"
9214H - 7/16"
T
Thunderbisciut
Cape Cod
Proto Wrenches, SAE, Many Kinds
First up satin finish 4 piece 12 point AntiSlip set - $25:
1212ASD - 3/8
1214ASD - 7/16
1216ASD - 1/2
1218ASD - 9/16
Black Oxide 4 piece 12 point AntiSlip set - $30:
1212BASD - 3/8
1214BASD - 7/16
1218BASD - 9/16
1220BASD - 5/8
2 Satin 12 point AntiSlip 9/16 wrenches(1 pictured) - $6 each
4 Black Oxide 12 point AntiSlip 9/16 wrenches - $6 each
Short Angle Open End wrenches:
3336 - 9/16 - $3
3332 - 1/2 - $3
6 point combo wrenches:
1212E - 3/8 - $3
1218E - 9/16 - $4
12 point combo wrenches:
1210T - 5/16 - $3
1224T - 3/4 - $4
12 point combo:
1208A - 1/4 - $3
Open end/flare nut:
3753 - 1/2 - $6
Open end/Socket end:
1270-16 - 1/2 - $6
T
Thunderbisciut
Cape Cod
Blackhawk Wrenches, New
Metric 8-15mm set(Part numbers make sense, sizes are right there) - $15:
BWE-89MP
BWE-1011MP
BWE-1213MP
BWE-1415MP
SAE 1/4-9/16 set - $15:
4020P - 1/4 - 5/16
4723P - 3/8 - 7/16
4724P - 7/16-1/2
4725P - 1/2 - 9/16
T
Thunderbisciut
Cape Cod
Craftsman RP USA Ratchets
1/4" Ratchets:
One with little rust - $3
Clean one - $5
3/8" Ratchets $8 each
1/2" Ratchet $12
T
Thunderbisciut
Cape Cod
Random Craftsman Insert and Power Bits
A baggy with a bunch of randoms. These are USA made, a few are a little rusty.
$5
T
Thunderbisciut
Cape Cod
Craftsman Metric and SAE Hex Socket Sets
Metric 34448 3/8 drive hex sockets - $12 each:
4, 5, 6, 7, 8, 10mm
SAE 34447 3/8 drive hex sockets - $12: SOLD
5/32, 3/16, 7/32, 1/4, 5/16, 3/8
T
Thunderbisciut
Cape Cod
Proto 360B 12pc Retaining Ring Pliers Set
This set has been sitting in what appears to be a hot dusty spot for a long while. The stickers on the outside are peeling up a bit, however the pliers look to be brand new.
The cheapest I've found this set is around $230.
This set includes straight, 45, and 90 degree convertible pliers with .038, .047, .070, and .090 tips.
$150 for the set.
T
Thunderbisciut
Cape Cod
Blackhawk Tool Set Brand New
I do not know the model name of this set, but I do know that it is no longer offered from Blackhawk. Everything in this set is brand new except for some of the insert bits that were missing when I picked it up. I filled in the 3 missing spots, and someone else filled in the other 4 missing spots before me.
Everything is USA made except for the bit handle which is China, the ratchets are Taiwan, and the original insert bits are unmarked.
Kit includes the following:
1/4, 3/8, and 1/2 ratchets with thumb wheels
Insert handle
5/8 and 13/16 spark plug sockets
3/8 to 1/4 reducer
3" 1/4 extension
3" 3/8 extension
6" 3/8 extension
2" 1/2 extension
8-15mm 4pc open end wrenches
1/4 - 9/16 4pc open end wrenches
24 insert bits including phillips, slotted, torx, tamper proof torx, and square
1/4 drive sockets:
4-13mm 6pt
5-13mm 12pt
5-11mm 6pt deep
3/16-1/2 6pt
1/4-7/16 6pt deep
3/16-7/16 12pt deep
3/8 drive sockets:
9-17mm 6pt
9-18mm 12pt
10-14mm 6pt deep
5/16-7/8 6pt
5/16-7/8 12pt
3/85-5/8 12pt deep
1/2 drive sockets:
17-22mm 12pt
3/4-1 12pt
Total 151 pieces...if my count is right :headscrat
The closest thing available now is the 130 piece kit for around $230.
$200 for this kit
T
Thunderbisciut
Cape Cod
Chicago Pneumatic CP 828 3/8 Air Ratchet
This air ratchet was hardly used. I took it apart and greased the assembly. The internals are in almost new condition. I have one of these exact ratchets, and it is a very nice unit. It is made in Japan. It's rated for 50 ft/lbs of torque. Tooltopia sells them for about $102.
$60
T
Thunderbisciut
Cape Cod
Craftsman RP USA 7-18mm Wrench Set
Most of these look to be unused. The 15mm open end looks like it was a little beat up and then ground down.
$25
T
Thunderbisciut
Cape Cod
Craftsman USA Tamper Proof Torx bits New
These are unused made in USA, sizes are: T15, T20, and T25. All are 1/4" drive.
$3 each
Status
