Re: Tig or might patch panels? Pro & cons ?
Mike, this is something I did this weekend:
Note full penetration weld:
Dressed and media blasted:
This was done with the TIG. The weld is softer for easier planishing, which by the way was minimal required, weld splatter is non-existent, I do not need a cut off wheel to grind welds down as I do with mig, and from start to finish (cut, trim, weld, dress) is about 1/3 to 1/2 the amount of time involved as compared to MIG. TIG normally requires more attention to detail in cutting out a panel and trimming/filing to final size before welding, as adding heat without automatic fill wire (as with MIG) may cause any slight gap to burn back the edges or blow a hole, so to speak. So yes, it does require more finesse. But in the long run, it will take less time and will give better results.
When I started using TIG a couple decades ago is was a Miller Econotig, which was not very accommodating with thin sheet metal as it did not have the lower range needed. It was better suited to 1/8" and thicker. So most of my rust repair work was done using the MIG, and the process you see me using in the above linked thread has focused on using a precise, methodical process that it can be easily duplicated by anyone to achieve acceptable results. Follow the process and you are side stepping many years of trial and error.
The process in a nutshell: Understand we are welding only ONE weld dot at a time. Set welder at higher heat for full penetration weld, adjust wire feed faster if needed to overcome blowouts. Start weld dots at one end of the seam and tack about every 1-1/2", aligning the panels together as you go. While the weld dots are spaced and more accessible, planish each weld dot individually to help stretch back out the shrinking that occurs as the weld cools. Then grind each weld dot, both front and back, to
just above panel height. This gets the area back as close as possible to the original thickness without getting too close to thinning the area. The panel thickness is what we based our heat settings. (leave weld dots and now you have metal up to 4X or more thicker than the sheet metal. This affects heat required and will result in colder joints, or insufficient weld penetration) Any sanding/final dressing I normally leave until the end to avoid any excessive removal of parent metal based on all the weld cleanup work required. Once you get done grinding welds, now go back to where you started and weld the next set of weld dots, overlapping the first set by about 1/3. This will help to eliminate the missed spots that occur from jumping around, as some advise you to do. This also explains why you start tacking from one side and work toward the other, if you jumped completely to the other end of the weld to "keep things cool", then you have more chance of panel mis-alignment which may result in more metal between welds on one side than the other, ie: instant pucker. So to recap, tack, align panel, space about 1-1/2", tack, repeat until the end of the seam. Go back to start and planish each weld dot individually, start to finish. Go back to start and grind each weld dot, FRONT AND BACK, start to finish. (this also gets welds out of the way for planishing the next set of weld dots). Then 1/3 overlap, and repeat each step.
I was tutoring someone on another forum recently in using the MIG and the process I've laid out in the thread linked above, stressing the planish and grind steps between each step. His pictures show many weld dots next to each other, no flat spots that would indicate planishing occurred, and yes, that would also indicate no grinding occurred. He posted pictures to find out why all the warping occurred, and why it didn't fix it when he used a shrinking disc. MIG is a pain in the *** to use but if any steps are skipped, the panel gets away from you so much quicker. If you're not used to seeing metal deforming after welding, it starts forming a wave, and people automatically think this is excess metal and they want to shrink something. SHRINKING is what caused this, it will never be fixed by more shrinking. The weld is pulling at the surrounding metal as it shrinks and the puckers form just outside the heat affected zone. The weld and HAZ must be STRETCHED to relieve the pull that the weld has on the surrounding adjacent metal.
The individual weld dots with MIG are used so we can set our welder HOT for a full penetration weld. Unfortunately this results in a weld that pulls from all directions. The easiest way to stretch it back out in all directions is while the weld is all lonesome, by itself, or while any adjacent weld dots have been ground down out of the way. As a comparison to TIG, you have better localized control of the heat with a TIG, so one can do a full pass, or as far as the length of filler rod will allow. This basically lets the weld and HAZ heat up gradually and cool down gradually as you work your way across the panel, for less shrink occurring over all the start and stop welds in using the MIG.
So my recommendation is to get proficient enough in cutting and trimming your patches for a tight joint so you will have better luck with the TIG, and use that machine. If you already have a MIG and don't see yourself buying anything else, please follow the process I've laid out to help in your success, it comes with plenty of learning curve already built in for you. Deviate from the process, you are now into trial and error.
Mike, I know we're more than a couple hours away, but if you would like to come down one Saturday when we're in the shop, You can try both methods and see for yourself..
