Tightening a keyed chuck...
MR2FC
Hi, I've been watching some pillar drill videos for purchase research purposes, and noticed some of them tighten a bit in the drill by using the chuck key in all three holes. One guy even said how important it was not to forget to do that...
It's been over 35yrs since I last used a pillar drill, but I don't remember my teachers telling me this, or my father (an engineer of sorts) when using keyed drills at home, I wondered what your thoughts were?
Thanks in advance
Jack_K
Australia
I read it recently too and have now done it a couple of times and there was a bit further I could tighten it using the other two holes. Whether it actually makes much difference I don't know but it does make sense.
kmacht
Connecticut
With the way a chuck is designed it mechanically doesn’t matter if you use one or three. Removing and reinserting the key to make take a second try at tightening the chuck will make more of a difference than using a different hole.
RoninB4
Under My House
JMO from decades of machine shop work, never made a habit of tightening all 3 locations. If the drill spins in the chuck you're either:
1) Feeding it too fast and it's grabbing in the material
2) Don't have an edge break (if drilling brass) and is grabbing the material
3) Need flats on the shank for a more positive mechanical drive
4) Have a chuck that's been over-tightened and is "sprung" (need to rebuild/replace the chuck)
2) Are just using the wrong machine for what you're doing.
Tightening all 3 locations shouldn't create hole that's more true to size, whether by drill or reamer. There's several reasons for an over-size hole with a drill/reamer.
RonnieC
Orlando, FL
I just use one. I’ve met some people who thought that somehow each hole was magically attached to one jaw rather than just providing a fulcrum point to apply torque via the key.
Could it be that due to internal loose tolerances that by tightening via one spot you force the internals laterally and it’s a bit off center? Maybe in a loose or worn chuck I suppose.
Viper98912
GA
I've only used 1 here...
I guess theoretically if your chuck was worn out, it could help (as previously stated above)
CraigStu
Blacksburg, Va
To me that would be a colossal pain in the ****. The actual tightening of the chuck is done by the collar moving the three internal pieces. I don't see how turning that collar from one hole is any different from turning it from another hole. Now, if one hole is worn out, then going to another hole could be better but I suspect that all the holes are probably worn about equally. Maybe 2 years ago I came across an extra chuck key for my old drill press. That just slightly used key definitely did help reduce key slipping. I also make it a practice to orient the key so I am pulling it toward the collar to help w/ engagement.
WillyBoy
Genesee valley area of New York state
I guess I'm the odd man out, I'll tighten one hole well, then move to the next hole counter clockwise and give it a snug, then let 'er eat.
This is what I do. For years, actually decades, I would tighten only one hole because, after all, they're all geared together. Last year I decided to check the tightness after "one hole". I found that after tightening the first hole to where the key wouldn't move any further, putting the key in the next hole and twisting a little more, I could get another 5 - 8 degrees of movement. Now I know it's tight.
No, I'm not throwing the chuck away.
Maybe it's just me but I think there are three holes so the spindle doesn't have to be rotated so far to find a place to insert the key. About one time in ten, the spindle doesn't have to be rotated at all.
Grimpala
On a lathe chuck I would always tighten all the key holes, regardless of number. I've carried that over the to the drill press to some extent.
P51Mustang
Central Iowa
Way, way back in high school my shop teacher said to always use all three holes when tightening the chuck. He said that it was to even the wear out on the chuck. I have no idea if this does help but even after a lot of years I still tend to do that.
niget2002
Josephine, TX
Why else would there be three holes?
So you can hit whichever one is closest without having to spin the darn chuck for 15 minutes looking for the hole. I guess if the room is well lit, the hole might be easier to find, but some of our workspaces are like a small dungeon with poor lighting.
kmacht
Connecticut
On some machines like a lathe the chuck stays fixed and the part turns. Having 3 holes makes it more likely to have one of the holes pointing in a direction that is reachable by the key without having to remove and reposition the chuck.
58Yeoman
Central IL
Wow! Earth shattering first world problem. Use one, two or all three. Geez. I've got a real problem here for you all to figure out: Do you walk to work or carry your lunch?
No wrong answer here.
dfiler2
NW Minnesota
I was always told to use all three and I still commonly use two because you can always tighten it a little more on the second hole.
Barnabas
Raleigh, NC
I was a high school shop teacher starting in the 1980’s, and this is the first time I ever heard of this. None of my shop teachers ever mentioned tightening three holes, and I never taught that.
It is important for the Chuck to be tight, so figure out what that means for your Chuck.
I like the modern Chuck keys that are spring loaded, so you don’t accidentally leave the key in the Chuck.
no704
I hate you and anyone else that puts springs on chucks! Lol. Not really, but they ****!
P51Mustang
Central Iowa
I have no idea where my high shop teacher came up with this but that is what he told us. This was auto shop and my teacher had worked for several years as a mechanic before becoming a teacher, so maybe this came keeping his tools in the best shape when he was making his living with them. He was a great auto shop teacher. He was one of the reasons that I went into engineering. I do not think this would have made any difference but this was in the early 70's.
nadogail
Coronado, CA
Usually it only takes one time for a new guy to learn to remove the key from a chuck before starting a Drill Press.
