My garage has a flat concrete slab with 2x6 walls.
Unfortunately, the slab has some low spots that pool water in a few areas. The slab is 44x60 and the low spots are fairly large but relatively shallow, maybe a 1/4 inch of standing water in the deepest areas.
It's not a big issue since it's usually dry, but periodically I may want to hose out the garage. That will create standing water that will need to be squeegee'd or broomed out.
I don't like water getting the sole plate and possibly sheetrock wet, so I've been thinking about what I could do.
What do you guys think about putting tile around the perimeter as a water resistant baseboard? I was thinking 3 inch x 12 inch bullnose tile with cement tile backer behind. What would be the best method to install to ensure it is waterproof?
Other ideas?
Other ideas?
