We're having 550 sq ft of porcelain tile installed in our home that was quoted using the Ditra heat floor warming cable system. My concern is that the Ditra cable and thermostat are only capable of 82 degrees F. max which will basically only take the chill off the tile. I know other cable systems are capable of temperatures of 104 degrees F. Has anyone used other brands of cable with the ditra heat membrane and if so are you happy with the results? This is a remodel over wood sub flooring so im not going to go consider hydronic radiant because of the cost and complexities involved retrofitting although if I were to build new that would be my choice. Any help would be greatly appreciated.
