schmiddy 219
- Joined
- Mar 12, 2018
- Messages
- 1
I am getting ready to redo the flooring in my 1600 sq foot garage. My installer says I need to grind off the old peeling epoxy coating. I started looking at Commercial Vinyl tile and then thought maybe I could do porcelain tile. However, both sides have a drain in the center of the sloping floor and I wash my cars in the garage especially when its cold outside(Heat and Air in the garage) so from what I have seen rigid tile would not work due to the drain issue. My installer says we would need to use an epoxy type glue since I will wash the car on the tile. Thoughts on this please or any other ideas please.
I have a bid of $6000. to do a new epoxy floor. Looking at 1600 for tile plus a $1.00 a tile to install plus labor and equipment to grind the floor should come in around 3200 to 4000 using this method.
The porcelain tile sounds great but the drain issue is the challenge
Also looking for the hardness specs and slickness specs for the tile
