Tiles come with three ratings from the manufacturer.
First off, there's a P.E.I. (Porcelain Enamel Institute) Wear Rating:
Group I - Tiles suitable only for residential/commercial walls. Not suitable and/or recommended for foot traffic
Group II - Tiles suited to general light residential traffic, except kitchens, entrance halls, and other areas subjected to continuous foot traffic.
Group III - Tiles suited for all residential and light commercial areas such as offices, reception areas and boutiques.
Group IV - Tiles suited for residential, medium commercial and light institutional applications such as restaurants, hotels, hospital lobbies and corridors.
Group V - Tiles suitable for heavy traffic both residential and heavy commercial applications such airports, malls and subways.
Then there's a Water Absorption Rating:
1. Non-vitreous Tiles - absorb 7% or more of its body weight in water. They are suited for indoor use only and considered to be non-frost resistant.
2. Semi-vitreous Tiles - absorb between 3% to 7% of its body weight in water. They are suited for indoor use only and considered to be non-frost resistant.
3. Vitreous Tiles - absorb between 0.5% to 3% of its body weight in water. They are suited for both interior and exterior applications (covered and/or non-heated rooms not exposed to standing water) and considered to be frost resistant.
4. Impervious Tiles - are the strongest. They absorb between 0 and 0.5% of their weight in water.
Finally, there's COF (coefficient of friction), with a rating for both wet and dry. This is how slippery the tile gets when it's wet. I don't know what the typical range is for ceramic tiles.
My cheapo tiles have a PEI rating of 'IV' (residential, medium commercial and light institutional applications). Obviously, 'V' would be the absolute ideal for a garage.
My water absorption rate is 3-7%, which means the tiles are not frost-resistant or frost-proof, and wouldn't cut it in an exterior application in a part of the country with sub-freezing temps. But then, I would guess Home Depot probably sells more appropriate tiles in parts of the country where it does freeze.
My coefficient of friction is 0.60, wet or dry. I haven't found much on the internet on this, aside from the fact the City of Los Angeles building code requires that level surfaces have a COF of not less than 0.60 and ramps no less than 0.80 when tested. I guess that would mean I'm just slip-resistant enough to be used in the local shopping mall.
