Hounddog
I thought I'd share a product I'm using now. It's called the Raimondi Leveling System (RLS).... helps keep the tiles all flat and lined up when laying.
The company has a good RLS tutorial that will also get you acquainted with their product.
First, a few disclaimers. I had a tile guy do my floor. He had used a version of this type of product about 4 years ago....so he didn't fight my desire to use it. I chose the RLS type because of the wider wedge which adds to a better leveling capability as it reaches more of the adjacent tiles.
The next morning I decided that I'd "breakaway" the product in order to get ahead of the grout guys arrival. I was trying to avoid a rush job so I also cleaned out the grooves containing squeeze out of the thinset. Beware here...you can easily chip a porcelain tile...use a utility knife to be safe. My initial selection a of 5 way paint scraper...(I believe it's called) ended up chipping two places...very small but annoying just the same. As the mfgr. video shows they break away but the first few did not break away clean below the tile.... So I decided that a lower angle of attack may help...it did, hence the block and dead-blow mallet. I did have to use my pliers a few times to coax a piece out on a few occasions.
"Hainging Chad" we'll call it
Happy with the results...it's flat and "lippage" was near zero throughout. Cost will roughly be $200 in the RLS material.
The grouting process...need to do a final wipe of the haze tonight
Here's video...there's others
If your planning a project...I'd recommend it to a friend.
