I am really impressed with some of the inexpensive VCT tile jobs posted here. The ultimate in my opinion is small (like subway tile size) ceramic tiles. That is what you see in some higher end shops. The big 12x12 or 12x24 inch ceramic tiles you see most here using are cheaper to install but will crack as time goes on from jacking on them, dropping stuff on them, etc., though they can be replaced.
I use pvc tiles but they cost more. With either hard or soft plastic, vinyl or rubber interlocking garage tiles, they will contract and expand with heat and cold. Leave your garage doors open in direct sunlight and you will see the first couple of rows of tiles buckling at the joints as they expand from the heat. They say to leave 1/2” for movement along the walls, but if you are like me, you will be putting stuff in your garage that will prevent movement, like cars, work benches, cabinets, maybe a lift.
I had my doors open on a very windy day earlier this year and all the tiles in the front were lifting up and buckling as the wind got under them and started lifting them. And my tiles aren’t the cheap light plastic ones that most people use. They are the heavy rubber or pvc ones that weigh several lbs each.
