Helping a friend tile his house.
Tiles are 20x20 porcelain.
House is a slab.
About 1800 sq ft install.
House built in 70's
All floors were carpet before
No cracks in slab (amazing) except a few hairline shrinkage ones. Used Redguard on those.
All walls are square & floors level.................except 1 room.
Family room has an area, probably 10x8 ft that's 1" low in middle.
Using 1/2x1/2 notch trowel
Using Flexbond thin set.
Tried a couple of experiments to float floor in small test area.
Used mortar patch on floor- let dry & comes up easily w/ chisel. Not bonding.
Tried using same mortar but used a bonding agent. Same thing.
Tried a leveling concrete. Comes up easily w/ chisel.
Tried leveling concrete w/ bonding agent- better but still not good enough.
So- we tried bonding agent along w/ 1" of Flexbond thin set- the grey stuff.
48 hours later- you would need a jackhammer to get this up!
Doesn't shrink or crack but am willing to bury a fiberglass mesh in it if deemed necessary.
Plan is to use 8 ft 2x4 & level middle low spot w/ this stuff- feathering out edges. After completely dry over a weekend, install tile w/ 1/2 trowel & same thin set.
Another guy where we bought tile says we might try multiple layers of Schluter uncoupling mat w/ thin set between layers to build up low spot.
One other guy suggests using a thinner Spiderweb uncoupling mat glued to floor using the thin set & then build & level on top of that. We are leaning towards this approach.
Opinions?
House is a slab.
House built in 70's
Opinions?
