Tile Specifications; How will this ceramic tile hold up in a garage?
usmc0517
Hi everyone,
Been going back and forth between epoxy and tiles for months now, and believe I have finally decided to go with tile. I've noticed several people have had good results using ceramic tile. I know porcelain is better but I haven't been able to find porcelain that I like in my price range. How will this particular ceramic tile hold up in a garage? (In Houston TX)
Material: Ceramic
Tile Finish: Glazed
Thickness: 8MM
Straight edge (rectified)
PEI 4
Frost Resistance No
Chemical Resistance Yes
Water Absorption Semi-vitreous
ADA Compliant Yes
Dry Coefficient of Friction 0.83
Wet Coefficient of Friction 0.64
Breaking Strength in lbs. Greater than 750
I was concerned with the "Semi-vitreous" rating, is this an issue in the garage?
Thanks,
Kevin :beer:
U
usmc0517
Hey Jack, I've looked at several of your posts, great looking garage!
I'm located in Houston Tx, and its an attached garage so I don't think freeze/thaw cycles will be an issue.
