bigcow - Looks great !
Can you estimate the auger diameter for the post holes?
And, the belt truck - Pros/ cons compared to trailered pumper?
And cost per trip?
Thanks, Marc
The holes are 18" diameter by 48" deep. Originally they thought they may have to use a pump truck due to soft ground and not sure if the concrete trucks would get stuck. The concrete guys refused this option as it would have involved setting the truck up in my house driveway, laying 200+ feet of pipe on the ground to the building and then having to carry that pipe around inside the building. All of the pump trucks around here are a self contained unit and run close to $1,000 to just show up. The belt truck ran me $650 and he was on site for a little over two hours. With my situation he was able to back the truck right into the building so he could swing the belt and reach the entire area of the first pour. The downside to a belt truck is you only have two axis to move (left, right and up,down). A pump truck has infinite capabilities and pinpoint placement.
The remaining section inside the shop and the approach they just backed the trucks in and poured straight out of the truck.
If I was in a situation where it was hard to access the building, a pump is definitely the way to go. If I was in a confined space say behind a house and it wasn't a big pour, I'd get a few buddies and rent a couple of concrete buggies. They can usually haul around 1/2 yard of concrete and are compact to get into some tight spaces.
Sent from my SM-G930R4 using Tapatalk
