Time for a new trailer deck
andyvh1959
Green Bay WI
My 5x10 tilt bed trailer I got used back in 2005 finally gave up the original wood deck boards to serious rot. I pulled off the remaining boards by hand, no tools required. I plan to use reclaimed/recycled plastic composite 2x8 boards from Menards to replace the deck. They are kind of heavy, like a Fir 2x8 versus a line 2x8, but being a composite means no rot up here in the great white north of Wisconsin. Anyone else have a similar option used on your trailer deck? I plan to use seven 2x8 10' boards, gapped about 0.83" between the boards for drainage.
4x4Pete
Stroud
Is there enough support for the composite boards? I know they are supposed to be comparable to real wood but they seem to sag if your beyond 16" centers. Edit- I guess that's what Jack meant.
ipgenie
Idaho
I was told to use 12" centers for a composite 'people' deck. 5x10 tilt probably won't have anything heavier than a mower or ATV so 12" centers would likely be fine. I'd bet you have 2' centers now so maybe just add a few.
Most composite decking is only 1" thick but I've seen benches with 2" composite boards so they must be available somewhere. I bet they are stinking heavy though. The 1" stuff is pretty heavy.
I tried 1" composite on my 4x8 Harbor Freight trailer and it sagged pretty bad. I added support and replaced two deck boards with some aluminum planks a friend gave me. The aluminum runs right where the tires go on my mower and ATV. It's been good for the past 15 years now.
asallwey
N. Virginia
So what do you carry in your trailer? Like, how much weight? What is the weight capacity?
Composite is heavy. This came from my first hit on Google, not quite the dimensions you mentioned, but think about total weight and how capacity may be affected.
Treated 5/4 x 6 wood decking on average weighs 1.59 lbs a lineal foot, an equally sized composite weighs 2.3 lbs. Making composite decking on average 45% heavier than pressure-treated wood decking.
65Goat
I vote for pressure treated.
Penofin for pressure treated wood is good but probably not necessary.
mfs54729
NW Wisconsin
I have a 5' x 8' trailer that had a plywood bottom that rotted out. I had a hard time finding a 5' x 8' piece of plywood let alone a pressure treated one. I found pressure treated pine porch flooring boards at Menards. They are 3/4" thick and 3 1/8" wide and tongue and groove. It gave me a solid perfectly flat trailer bed, no rounded edges like decking boards.
Walkers
Cave Creek Az
If you plan on having it ****, then the recycled wood is perfect. Just don’t put anything heavy on it, or use it on the road and it will work great.
Leaflessshadetree
Don't ask.
Used motor oil (I don't get why people do this) is not necessary. White oak is naturally rot resistant. I'd choose a stain or sealer that won't make a mess, but to each their own. My oil gets recycled, not dumped on stuff
What mess? Wouldn't you consider this recycling? Actually I think of it as reuse and avoiding the need for other (possibly more harmful) chemicals.
mike93lx
Richmond, VA
I consider it spreading something containing heavy metals and all kinds of other bad **** on a tool that I regularly use, plus the issue of run off when it rains.
No, it isn't recycling, it's reusing.
I'm good
kwb
PNW
Composite deck isn't going to do well with point loads that are common on trailers.
You got almost 20yrs out of the first go around. That seems like a reasonable life and window for going around the whole thing for a freshen-up. 99% of the trailers I have seen the wiring ***** as far a preventing abrasion points, light housings turn to junk, etc.
New wood deck, new wiring, new paint. Rock that thing for another 20yrs.
Renegade1LI
long island ny
If you're really worried put down some PT & spray it with Thompsons every year, should get 30 years out of it. PT is relatively inexpensive & strong, yellow pine will handle abuse no problem.
KansasArt
Kansas
Find someone on CL selling used deck lumber. If it’s not rotted, you’re gtg. New composite is probably close to what the trailer is worth.
Mr.N
Mpls, MN
Well the spot right under my off road only Jeep where it leaks oil it looks like almost brand new wood. Other areas the white oak has rotten through and I am replacing
Understand your concern and maybe with where you live it is not needed... but I will never go without.
mike93lx
Richmond, VA
Well the spot right under my off road only Jeep where it leaks oil looks like almost brand new wood. Other areas the white oak has rotten through and I am replacing
Understand your concern and maybe with where you live it not needed... but I will never go without.
You sure it's white oak and not red oak? They perform completely differently in weather.
I spent the last nearly 40 years living in New England, so snow, salt and rust are not foreign to me at all
mike93lx
Richmond, VA
I'm about to re deck my trailer also. I've beed told to use Alaskan yellow cedar. Any thoughts about that?
Durable and rot resistant. If it's available, it would probably make a decent deck. About a third less dense than white oak, so it would save some weight
