Time to join the wilton crowd
D
don long
southern california
I thought $100.00 was a fair price for it. I just came in from out in the garage looking for a production date on the vice but couldn't find one.
I took the vice apart and looked on the bottom of the shaft but nothing.
I found this on the pivot. Is this something
The jaws look pretty good. Won't take a lot of work to make them look good again
D
don long
southern california
Thanks for the help guys.
The 40's were good years I believe that's my era.
I was quite happy with the price
To use a line from The Princess Bride.
Inconceivable
Don Long is just now joining the Wilton crowd 😱
Well not exactly Bama
I think I can find maybe 5 or 6 of them around here but this one is by far the nicest.
My go to vice in the shop is this 8" wilton
and this one has been sitting on the shelf for a few years. Unfortunately the roof leaked and it has been wet several times and is stuck open
So tonight I poured some rustoff down the throat and will let it sit for a couple of days before messing with it
And the last one in my garage is the one that sits on my Pennzoil bench
So I figure it's time to come out of the closet lol
Roberts210
Missouri
Thanks for clarifying Don. The one at Anderson Plywood happens 4 times a year. It's where I bought my 4-1/2" Wilton Machinst vise in the early 1990's.
Luntz
Franklin TN
Don, I recently purchased a 4 1/2" Wilton with apparently no date code.
On a whim, I removed base guide and flipped it over. Lo and behold, there it was! January 1949.
larry_g
oregon
I have one of those #3 vises. I wanted to make some brass jaws for it and did. I drilled the hole for the locating pin first and found that the jaws would stay in place just with the press fit on the locating pin and did not require drilling the screw holes for retaining the jaw. For me there is a great advantage in having a full flat face for holding small parts.
lg
no neat sig line
D
don long
southern california
Looking for a fun small project to start the year off I walked over to the table with the wilton Vice on it and said this one will be a good starter.
So with a little clearing of a workbench I put the #3 vice pieces on the bench and started putting a plan together as to what I want this little project to look like.
1st the casting marks must go
2nd the casting pits must go
3rd the jaws need to be reworked
4th I want a chrome handle so I must find a way to get the handle out of the yoke
5th a good color scheme that matches the pennzoil garage must be chosen
Let the games begin.
I took the movable jaw for my first piece and went to work removing the casting seam at the base of the jaw
And there is another one in the front of the jaw just like the rear that must go
So with my die grinder and an 80 grit disc the grinding started.
next I went to the shaft. It looked like someone had missed what they meant to hit several times and gouged the vice badly so I smoothed the shaft with the grinder. With the casting seams and the gouges gone it was time to concentrate on the pits and irregularities on the body of the movable jaw. First the die grinder then the pistol grip air sander with various grits of sandpaper gave me a pretty nice looking vice piece
The shaft will be polished a bit more to give it a chrome look. the small jaw was removed and with the help of my wire wheel on the bench grinder the grooves cleaned up nicely and a couple of passes across the belt of the Burr King belt sander the gouges in the jaw went away so it looks good again. A little masking tape before priming and this piece will be ready for the paint shop
Roberts210
Missouri
Don, your 3" vise is a war-time vise, and was cast in either 1941 or '42. It was assembled before 1945, and was sold to either a war industry or to a branch of the military. The jaw inserts are original. Wilton did not sell vises to the public until 1945. The give away on the casting date are the so-called fish hooks, and the give away on it being a pre-1945 vise is that there is no date stamp on the slide.
D
don long
southern california
Thanks for that info Robert
That's nice to know
D
don long
southern california
It was a rainy day in So Cal today. A good day to play in the shop so I spent the morning working on the #3 vice.
I grabbed the other half of the vice and started cleaning it up like the first half. This side has a much bigger area to work with but it also has script that I want to leave intact so I will have to take a dremel to clean between the letters. A little more time consuming but well worth the effort. After a couple of hours and some tired hands the vice went from this
To this
A little bondo to fill the pits and a little more polishing on the anvil area and the vice was ready for primer
I covered the polished area and off to the booth the vice went
Roberts210
Missouri
There are some "fish hook" vices with date stamps. Evidently Wilton had a ****-load of castings made in '41 and '42, and some were never assembled until after the war was over. Those vices got dated on the slide, and were sold to the public.
Fierljeppen
Greetings and salutations!
Wilton Tool Corp. vises weren't exclusively sold to the military during WWII. There are many magazine and industrial catalog ads that offered Wilton vises directly to the public.
I'll assume that you got your information from the "About Wilton Tools" on the Wilton website. Unfortunately, almost every claim on that historical thread is incorrect. One would hope that a well established company would know it's own history, but in this case, the current owners of Wilton don't even seem to care.
You are absolutely correct about the "fish hooks" being the first style of castings. And yes, they made a gazillion of them and stored them until sales dictated the need for machining, painting, assembly and packaging.
The best way to determine whether a Wilton vise was assembled pre-or-post 1945 is to look at the location of the pin for the main screw nut. The lower pinned nut would indicate pre-1945, while the more centered pin would indicate 1945 or later. The transition of this change happened in the earliest of 1945, so you will find some of the earliest Wilton vise date-stamps with the lower pinned nut.
"don long's" vise clearly has the lower pinned nut, so it's definitely a pre-1945 version. The earliest vises also had the acorn nut for the swivel base, also seen on this vise.
Anyway, it's a beautiful example of an early Wilton no. 30S machinist vise and I look forward to seeing the final restoration.
D
don long
southern california
Thanks guys
I worked on the vice a little more today. One of the puzzling issues I was having was how do I get the handle off the screw to polish it up?
Once I figured it out the run began and the handle now looks like chrome!!
Now I must find a way to fix the knob back on the handle and polish it up too.
THe vice is all sanded and ready for the primer/sealer coat and I'm debating weather to paint or chrome the base plate and end cap.
D
don long
southern california
Great job Robert
I found a few minutes to work on the vice today. I managed to get my handle back together after polishing it up. I pinged the edge of the shaft back over the ball then polished the ball to match the rest of the handle
I sprayed a second coat of primer on the 2 halves of the vice thinking that a light scuff and the vice should get color tomorrow
And tomorrow I'm heading out to the chrome shop to have these few pieces chromed then this project will be ready for display
There are also pieces for a safety can and a second vice going in.
D
don long
southern california
