Time to Replace the Well Tank
PirateTurner
Trenton SC
I have a 20+ year old Champion tank that is in need of a replacement. Looking at Amtrol-X and prices on the web run from $600 to $1000 for a 34 gallon model, some with shipping. Any recommendations on where to purchase?
zak77
Monson, MA
I have a Well Rite pressure tank that replaced a 25 year old Amtrol, my well guy recommended against a new Amtrol, something about a weak fitting breaking on the newer ones. So far so good.
Sturgeon
W. Mt.
If tank is sitting on concrete make sure you put a hot water tank pad on floor first. It will hold off the rust for a little while plus will make installation a little easier.
Whitworth
What's better quality versus big box?
What? One lasts 17 years the other 16?
Too many variables, how hard is your water, PH, etc? You could have the most expensive setup and have it get clogged up 90 percent with calcification in 10 years. Or get pinhole leaks from acidic water.
And match the capacity, different size tanks use different pipe sizes.
acer66
Western North Carolina
I bought a 52gl ish ao smith at Lowes this year and it had a galvanized pipe fitting.
Was in the middle of the install when I saw that so I cussed “a bit“ while I still installed it.
Did not think that was still a thing.
Needless to say my review at Lowes was never posted. 😛
larry4406
Northern Virginia
Following.
We have a Well-X-Trol WX-203. Its 32 Gallons allegedly. It was used from a tear down house that I kept and put in my house couple years ago when the original of same make failed.
Some of the units have a plastic edging at the bottom to separate the unit from resting on concrete.
Blk88GT
Manitoba
My galvanized fitting on my new tank decided to spring a pinhole leak - while I was on vacation on the other side of the country.
Find one with a brass fitting...
P
PirateTurner
Trenton SC
I drilled a couple of holes in the old tank to drain the pressure and water. There was some nice black iron sediment in the old tank. No wonder the water tasted bad.
Yesterday, working slow, I got the tank set and plumbed. The tank sits in a hole about 2' deep, OBTW. I used two 8" concrete blocks to keep the the tank off the sand floor. The walls of the hole are concrete blocks and are about 4" shy of reaching the top soil. Since the topsoil is mostly sand, a lot of it has pored into the hole over the years.
The original install used Sch 20 1" PVC. Of course, it cracked when I made the cut at the base of the hole and I didn't realize it until the pressure test. Had to demo a section of the hole wall to get to "clean" pipe. Turned out to be blessing because the pipe runs really ended up in a more direct flow.
FWIW, I installed a 30 gal Well-X-Trol (wx-203). It's nice to not hear the pump every time a faucet is opened. Thanks to https://www.supplyhouse.com/ for the quick ship and leadfoot145 for the recommendation.
leadfoot415
Livonia, MI
Yesterday, working slow, I got the tank set and plumbed. The tank sits in a hole about 2' deep, OBTW. I used to 8" concrete blocks to keep the the tank off the sand floor. The walls of the hole are concrete blocks and are about 4" shy of reaching the top soil. Since the topsoil is mostly sand, a lot of it has pored into the hole over the years.
Glad you had a good time ordering from them too. I still havent gotten around to installing mine as it is at a vacation property, and spare time is hard to come by. I am dealing with old pvc pipes leading into the pressure tank too, so I'm sure it will be a similar clusterf*ck.
P
PirateTurner
Trenton SC
leadfoot415: My after-action-review; cut old PVC with a saw, not a guillotine cutter, especially sch 20.
H2O Mechanic says it is a 40 min job to change out a tank. Haven't seen him do one 2' down in a hole.
