Tin Snips
KnurledNut
n/a
bonneyman
Desert SW
I've tried alot of different aviation snips. I've found Lenox brand that metaldad gifted to me to be superb!
Malco Zip Snips are my second choice.
Jim Caudill
Near Dayton, Ohio
The OP is looking for snips recommendation for cutting .040" to .060" and you guys are suggesting Midwest aviation-style snips? I've got to try a pair of those out. For .060" I'm either using a saw or a shear.
KnurledNut
n/a
Never had a problem cutting 16-20ga Al.
I
iagsxr
Vinton, Iowa
I should have mentioned that I have access to a stomp shear for long, straight cuts.
Most of the body of the car in my avatar is .060" with a few small .040" pieces. .040's no problem to work with even with my old, worn out snips, .060" was hard to make clean cuts. I may try .050" this time.
Thanks for the recommendations so far. I've heard Midwest are good. It's just hard to believe something can be both cheap and good these days.
bonneyman
Desert SW
Yeah, I kinda missed that requirement during my first read of the OP. A senior moment. :sad:
kkroger
Midwest or OLD Wiss, the newer ones are not that awesome the "Crescent Wiss" stuff...
Malco is offshore now... not that this is a bad thing but I've never had import Aviation snips that were worth carrying out of the store...
Wamsutta
Amarillo, Texas
I've been impressed by the Wiss snips. Although they're only about $10 at HD, they will cut paper immediately after cutting steel banding material. They will also cut cellophane after cutting steel banding material.
bonneyman
Desert SW
Aww, I thought that Malco might have gone foreign. Their new line of screwdrivers and nutdrivers (well, since 2014 IIRC) went Chinese, but had hoped their line of steel tools was still stateside.:mad:
BTJHP
TX
Midwest Bulldog snips are rated for 16 gauge cold rolled steel. I think they will be ok for the same thickness aluminum.
KnurledNut
n/a
They still are.
That guy made a blanket statement that was not true.
Mohawk Dave
SoCal
A good video someone shared on GJ years ago.
<iframe width="560" height="315" src="https://www.youtube.com/embed/qAOQfUaRZyw" frameborder="0" allow="accelerometer; autoplay; clipboard-write; encrypted-media; gyroscope; picture-in-picture" allowfullscreen></iframe>
goldtang
Western Australia
Wiss left , right and straight had them since I about 1980 and a couple of old Gilbow have no idea how old bought them second hand and scores a set of Milwaukee left right and straight when I bought one of their tools just before Xmas not sure as not used them
bonneyman
Desert SW
They still are.
Cool! I know the new nutdrivers are the "stinky" cellulose acetate stuff, and - though the nut runner bits look pretty cool - I'm not gonna try the drivers. There's enough smelly stuff in the tool box.
HenryAZ
MEMBER EMERITUS
South Congress AZ
For straight cuts, I have come to love my NWS English Pattern snips. I have the largest model (078-12-300), with 75mm jaw length. Fully open, the handle ends are 12.5" apart. For some cuts, it helps to rest one handle on the bench and push down on the other.
Copymutt
Colorado
In the process of making my own soffits. Why? Because none have been available in the width I need for 9 months!
Price of 24 gauge sheet is now twice the price of last yr., so screw that.
Bought 20” wide galv. 28 gauge flashing for the project.
Darned if every set of snips would not trim off a 1/8 or 1/16 edge. Wiss, Diamond, Crescent. Left and right.
Quick sharpening by running a 1/8“ cut off wheel along the near horizontal face brought them back to whisker cutters. Don't really know how they are supposed to be sharpened, but I have to assume it involves separating the blades first.
I usually sharpen without separating, often the pivot is peened over, and shears off when you try to remove it. I open them as far as they will go, and look for damage on the large inside faces. Fix that first, but try to use a very light touch. Then I work on the small bevel that does the real work, filing with an appropriate sized flat file, working from the pivot toward the tip, and from the outside towards the inside. You want to improve that bevel ‘til it comes to a reasonable angle, not a curve. Flip over and repeat. Try to file equally on both faces, and again, go no further than needed. If you go crazy filing, you might foul up the geometry, (don’t know, never tried With tin snips, but have over worked scissors and destroyed them.)
bonneyman
Desert SW
Just to throw another name in the thread about snips.
Klenk
1madmouse
Redding,CA,USA
I have a pair of Klenks, but they seem to be too big for my hands, meaning they open a bit farther than I can open my hand. So I can't get a full cut with them. I also know when I went to get new Reds and Greens for sheetmetal work, they are Midwest, not Wiss and the offset jaw models cut circles better than the regular blades, at least in my experience. I seem to remember something about Cooper in snips.
ecotec
I have 3 pairs of the Max2000’s (red, green, and yellow). I think that they are much better than my Wiss’s and Midwest’s.
