Hi all,
I just installed my first mini split. I tried to do it by the book with all the right tools and procedures, including a nitrogen pressure test and triple (quadruple, actually) evacuation.
The tests went great (300PSI pressure, 125 micron vacuum) and I released the refrigerant.
The final step was to re-insert the valve core into the service port with my core removal tool. After inserting the valve core, I put "Big Blu" leak detector on the 1/4" port and opened the core removal tool's ball valve as demonstrated here:
When observing the leak detector I believe I found a very small leak because I could detect some bubbles forming. I thought that maybe I did not put the valve core in correctly so I removed it to try again. When I removed it, it appeared like this:
If you click on the photo and look at it close-up, you can see that there appears to be a flaw in the clear rubber (?) gasket component - kind of like a small "hair" coming off the bottom. Do you think this imperfection would cause a small leak? Any advice on how to proceed? I'm thinking that I should buy a replacement valve core and hope that the problem was just that the original is defective. But how do I find the correct valve core - or are they all the same?
For now, I have left the valve core removal tool attached and have the ball valve in the off position to hopefully contain the leak while I figure out what to do. Thanks for any advice!
