Tip for putting on tire chains
Bunchgrass
North Idaho
I figured I throw this out there as it was a godsend to me when trying to put heavy chains on my tractor tires. I saw the video on Youtube from a commercial tire chain place in Norway.
Lay out the chains directly behind the wheels as close as possible to the tire and with the surface you want to end up in contact with the ground facing up. Using some heavy twine tie onto the leading edge of one side chain and run the twine through/around the wheel and attach to the other side chain. Do the same for the other wheel. Then drive forward slowly and the chains will feed themselves onto the wheel. Stop once or twice as you move forward to align/adjust the chain positions on the tire and attach the connectors when the leading edge has made it just beyond the rear of the tire. Much easier than trying to lift a heavy chain and set it on a tire.
Much easier to do than to explain.
WoodsTruck
If you get on and off the tractor to help align the chain, have a block of wood for each tire to park on when you get the chain where you want it. It allows the cross links to get pulled under the lugs easier so the chains are tighter the first time.
mark#3
I laid the chains out flat, drove the vehicle so the tire was a little past the center then stopped.pulled the chains up over the tire, then hooked them up
Then I took some #4 copper wire tied it across vertically/horizontially, took a big screwdriver, put it in the cross section, twisted the copper wire to tightened up the chains on the tire.This was while working for a power line const. contractor in the backhills of Oklahoma near Cookson.
So I was making do with what I had.
gnpenning
I have more questions than answers.
Some are confusing putting chains on a light duty vehicle with a larger vehicle. How I put chains on my pickup and my tractor with 6' tall tires are a little different or even 3 rail chains on my heavy duty trucks. Letting the vehicle put the chain on for you saves the back.
Bretny
Dutchess county NY
I have had chains on my 1957 ford for about 6yrs. The only tensioners I have used where the ones that are built into the chains. I had to tighten them up by one link a few years ago. I think they have been off once.
I always put chains on, drive a bit then re tighten them. You will almost never get them on perfect the first shot.
