Tips for Keeping the Garage "Secure"
wssix99
Chicago, IL
Thanks for the response's
it's detached....
my biggest concern is someone driving there vehicle into my garage door.
Caving it down and ransacking the joint.
That's a good concern. If I were to break in to a detached garage, I'd just use a utility knife to cut through the wall. (Often around here they are just sheeted with exterior drywall.) ...Then I'd ransack the joint. No need to mess up my car driving through the door.
Detached garages are the worst for security. On top of that, garages are really meant to store cars. If you have other valuables and are short on space, you may look at leasing a storage space. There are lots of 24hr climate controlled places in the city that will be much more secure and go for reasonable prices.
Diverbill45
Lebanon, Oregon
A friend of mine has a shop (business) in an area that is out of town and on a well traveled road with only a few other neighbors around. The shop is rather tall (I think it's 16 feet, or taller, to the rafters) 40' x 60' and part of the upper area is used for storage. In the past, he and his neighbors have had a few problems and were deciding what would be the best solution. He finally came up with an idea and the neighbors were all for it.
Seeing that he is always going to auctions and picking up all kinds of items, it didn't surprise me when I found out that he had finally got the perfect alarm system. He found an old air raid siren that use to be mounted on the tops of city halls. These are the ones that you could hear about 5 to 10 miles away, when they went off.
He mounted it up in the rafters so it was almost out of sight. When he wired it up he ran the wiring from his house so that it was on a seperate circuit from the shop, just in case a theif was smart enough to trip the main breaker in the shop. He also wired it to a 30 to 45 second delay. This way the scumbag had enough time to really get into the shop and away fom his point of entrance. Since his shop is not the cleanest and most well picked up shop around, there is the chance of tripping over stuff, if you're in a hurry.
He did a quick test on it (ran it up close to half speed) and all I can say is you don't want to be anywhere around that buildng, much less inside, when that thing goes off. :eek: :eek:
If the ear, eye and nose bleeds don't get you, running through a dark shop with machinery in the way trying to escape, definally will. :shocking:
dolfans
North Carolina
What if it is a detached garage that is only metal siding and 2x4's inside with a door that opens on the sides? Put a bar across the inside so cant be opened and padlock on the outside?
NUTTSGT
Northern Central Ohio
good stuff boyz
lemme ask
how do i or where can i buy a motion sensor that can trigger more then just one light or sirens? thanx
You can use a regular twin bulb motion light and a 120V siren. Replace one bulb with a plug in socket. Put a plug on the siren and plug it in. Aim the sensor at the door, along with the light. They come in, trip the sensor, get blinded by the light and deaf by the siren.
I'd suggest putting the motion light on a wall switch. This allow you to turn the light off before you trip it. I don't think 99%of the theives would attemp to turn on the lights.
Another thing I'd recommend is to reinforce the door jamb if you have wood jambs. Use some longer screws in the hinges and striker plate that actually grab in the studs. I'd also use a piece of 10 ga steel under the door trim, screwed into the studs. It'll slow down the door kick in process.
4wd4ever
New Westminster BC
This is going to sound strange but....I knew a guy who used a motion sensor to turn on a stereo he had set to play various sounds like someone running, the cocking of a shotgun, and crashing like someone tripped over some stuff running out to the shop...sounded really funny when you knew what it was, but would prob scare someone off.
I saw a motion activated sprinkler once at Lee Valley tools...always wondered if you could fill it with pepper spray or bear spray?...
LT4
TX
Target practice in the back yard every now and then. Obnoxious dogs.
