QwikKotaTx
My garage has horizontal Hardie siding and I am going to be adding a 36x48 window to allow for more airflow and for adding a window unit. I plan to insulate this "winter". On the house windows it appears the window trim (1x4 wood) is simply placed on top of the Hardie siding, not cut back to allow the trim to be inset which looks nicer. I am not too concerned with looks just want to keep out the elements. I plan to cutout the area shown below and add a header at the top of the wall and jack studs as well as a few studs below the window.
When I am cutting the siding do I make an opening just slightly larger than the window nailing fins or do I cut it back until it lines up with an existing 2x4? Ideally I would position the window so at least the bottow or the top lines up with taking out a whole section of siding rather than having to cut it down the middle but that makes placing the header become rather specific. The siding is only on top of tar paper, no OSB or ply underneath.
House config
New window spot
House config
New window spot
