myredracer
Have a new HF 240 volt spot welder I want to use on a car restoration. Doesn't seem to be a whole lot of info. around on using a portable spot welder.
Seems like you pull the trigger for in the range of 1/2 to 2 seconds. Some spot welders (fancier ones I guess) use a timer. I can do some testing on a few coupons. Is it as easy as just making sure the welds on the test pieces don't pull apart? Is the timing critical? What about welding 3 layers of sheet metal. Weld two together first, then the 3rd piece or all 3 at once?
The arms aren't parallel. Does it matter if the tip surfaces aren't parallel? Someone on the internet sells an arm that would make the tips parallel or I could make one I guess.
What about pressure between the tips? How do you determine what is right without getting a force gauge? How important is that? Maybe there's the right combo of time + pressure to get a good weld?
I have a picture in my mind of eventually driving down the street one day and having body panels falling off so I want to make sure the spot welds are all good.
