I'll be welding 5' pipe extensions onto 2" galvanized schedule 40 pipe. I'm a bit concerned about metal fume fever. I'll be welding outside and plan to have a helper with a box fan blowing fumes away. Do you think that will be sufficient? I have 32 joints to weld. I have a 3m full face respirator but it doesn't fit well under my hood. I have another respirator that needs new filters and it looks to have an attachment for a flip down shield but I don't have one. That doesn't fit as well either. Is it worth spending money to set that up, or should I be fine with the fan and holding my breath? I'm flap disk sanding all the seams to remove as much as possible from the outside of the pipe, but the inside can't be removed. I'm using the $90hf mig with my Miller 180 as a backup. I tested one and beat the hell out of it with a sledge and it holds just fine. Thoughts?
