2mJps
What kind do you have or have used at work? They all seam high priced for the DIY.
I use a cheetah at work. I don't use it that often but, it's a lifesaver when you have a difficult to seat tire.
I bought mine on ebay for $50 shipped.
nobody uses starting fluid and a match anymore? The tire jumps around a bit but it works ok.
I built one from an old propane tank. Welded a schedule 40 coupling into a hole I cut with a hole saw then attached a ball valve with a ******. Took a stub of pipe and heated the end so I could hammer shape it the way I wanted. In the port where the valve was I installed a setup from an old portable air tank to fill and it also had a port for a gauge.
Thing works mint. I run it to 80 or 90 psi.
