Tire Mark Removal
BoydS
South of Houston
My shop was just recently completed, but now I have tire marks on the slab from the JLG that was used to erect the steel. The slab is 2400 sf and there's quite a bit of tire marks. Any suggestions on how to remove them..? The finished floor will not be epoxy, but rather a hardener and clear sealer. Not sure if pressure washing is the way to go. I do remember, that you can rent one of those Clark floor machines and that may work. Any thoughts..?
Thanks..
'the epoxy floor guy'
Iowa
If COLOR only is what you are looking to 'fix'. you can GRIND them with a Concrete grinder.
For tire marks to just 'scrub' them off the BEST thing I have found is a Cleaner recommended to clean RIMS of tires.
This has a special solvent in it that takes off the 'tar' based stains.
I would give this a try. Straight. Spray it on give it a minute to 'soak' then using a scrub brush on a handle scrub them off.
Good Luck!:thumbup:
