I know this is a stupid question, but why are you branding the tires?
Is that a way to permanently mark vehicle tires?
- or something that will last longer than a wax crayon.
I keep looking at my metal stamps and torch.
I mark tires so I know where the summers tires go and where the winters tires go.
I'm assuming since he does four wheeling and that he has large expensive tires, he wants to brand them in case they ever get stolen.Just for the record, the OP (Mr.N) never told us why he wanted to mark the tires.
We have a winner!I'm assuming since he does four wheeling and that he has large expensive tires, he wants to brand them in case they ever get stolen.
The last 4 numbers are a date code. It's not a unique number per tire.The tires already have a unique serial number molded into the sidewall. Can't you use it?
Look for the DOT number followed by a unique sequence.
I'll give that a try and also hit the inside with it!Well, since you said "or something that will last longer than a wax crayon", I'll tell you that I've used Sharpie markers on tires (the silver ones) and that stuff stays on FOR A LOOOOOONG time.
We have a brand at work with interchangeable letters for branding OTR tires with serial numbers. I would think as long as you don't get carried away with the heat youl'd be allright.
Thank you both, very good to know. My sidewalls are extra thick, so I don't think a little brand will do much.Brand them. The 24.5's on my Freightliner even have a spot on the sidewall, an open box, marked "brand here".
Go to any truck tire sales/repair place. They can probly do it for you.
Thanks for the link.tire crayons dont wear off that quick....and if you brand them, what about the following season? theres a 75% chance that tire wont be in the same position depending on your tires and your rotation habits.
Tire crayons are not the same kind your kids play with.
https://www.google.com/#q=tire+cray....,cf.osb&fp=cc4e61ecb303b1a9&biw=1680&bih=900
The dot number IS a unique number. The last 4 just also happen to be the date of manufacture...but you would need proof of purchase of those dot numbers. Since the dot numbers are exposed, someone could claim you just took the numbers right off the sidewall.
