littletoes
Tell me what you trust guys!
I want to stock up on some more patches. All I've ever used are the Napa brand.
I have plugged over 1000 tires with https://www.amazon.com/Tooluxe-50002L-Universal-Repair-35-Piece/dp/B002I52RG0/ref=sr_1_6?ie=UTF8&qid=1488824018&sr=8-6&keywords=tire+plug and works great, even did a couple in the sidewalls of my personal car back when I was broke.
It's been a long time since I worked in a tire store but we didn't plug steel belted tires back then. The word was that the steel would cut through a plug and the tire would blow out. Is/was that true? or do you only plug tires with non-steel belts?
Nice kitI have plugged over 1000 tires with https://www.amazon.com/Tooluxe-50002L-Universal-Repair-35-Piece/dp/B002I52RG0/ref=sr_1_6?ie=UTF8&qid=1488824018&sr=8-6&keywords=tire+plug and works great, even did a couple in the sidewalls of my personal car back when I was broke.
It needs a reamer.Thanks for clearing that up guys.
I like the idea of carrying the Nealey mini kits in each car.
It needs a reamer.
I'm surprised they don't have one.
I used to work in a tire shop and I've personally repaired hundreds of tires.
I don't think anyone in this thread has mentioned the proper type of repair, a patch/plug. That's the only type of repair that's RMA approved.
Plugs alone or patches alone are not approved repairs by the RMA.
https://rma.org/sites/default/files/prp_wallchart1111_0.pdf
If you are going to plug, I recommend Safety Seal brand. However, it's not the best type of repair and if I was a shop owner I'd only be doing RMA approved repairs.
Here's a simpler type of patch/plug that's quicker and easier but still meets the guidelines.
http://www.safetyseal.com/safetysealplus.php
No, the Nealey kit doesn't normally need a reamer on motorcycle, passenger, and most light truck tires (you might need a reamer or drill to open up the hole a bit on very heavy truck or equipment tires just so you can get the repairs in there).
It works differently than other "sticky string" type repairs.
More reading that addresses this and other questions:
http://www.tirerepairkit.com/easyuse.htm
http://www.tirerepairkit.com/FAQ.htm
I've used these many times on tubeless motorcycle tires and car tires with no issues. Upon demounting, the knot on the inside had formed a very firm, close seal on the inside of the tire, and had bonded firmly with the tire -- the repair was very difficult to pull out from the inside.
I had read all that and watched the youtube video.
Have you ever plugged a run flat?
You NEED a reamer.
Me too ! That was my second job ever !I used to work in a tire shop and I've personally repaired hundreds of tires.
That manual is pretty far out there; as if written specifically for legal protection. And just who are they approving, anyway? Do they have regulatory power in any useful capacity?
Their procedures, while competent, take much more time and energy than a plug. That's money you've got to charge the customer. Suddenly, what used to be an in and out tire repair is now a long, expensive project.
You can line up Safety Seals in a sidewall and they'll hold pressure. Stuff four in a large hole. Put them in the shoulder. Heck, anywhere around the tread section a Safety Seal will last longer than the tire it's in.
They've been good enough for me in the toughest situations, and always held up for the journey and the life of the tire. High speed, low speed, rocks, mud, gravel, tarmac; it doesn't matter. They hold. Period.
Any regulation ought to consider the simplicity and permanence of this repair before mandating complexity.
You NEED a reamer.
We don't fix run flats. You are buying a new tire if you have a run flat or you can fix it yourself.
We called Goodyear a few weeks ago and they said do not fix them as well
I just plug them
have the same tool, love it. it occasionally goes on sale for $11.99
I prefer the black plugs, they seem sticker to me, so I buy those for refills.
I don't know what brand patches I have, I pick them up all the time on clearance or flea markets so brands are pretty varied...
the cement stores fine in the cold garage as long as it hasn't been opened. for that reason I stock up on the little tubes and just toss them once I open them.
I plug any and everything. if it holds, it holds, if not, maybe a patch. I've even done sidewalls on newer tires and not had a problem.
I know many people who are vehemently against fixing any tire and regularly thrown them away before they age out regardless of usable life...so you'll likely get varying opinions. but for me, if the plug holds, the tire rolls....
Not an issue at all nowadays -- they made the plug material tougher.
The Nealey tire repairs are my favorite -- I carry Mini Kits in my cars and on my motorcycles with tubeless tires.
http://www.tirerepairkit.com/whichkit.htm
Nice kit
I just have the $5 cheapo kits.
1 in each vehicle
The issue is you don't break the tire down when plugging a tire. Therefore you can't see if it's damaged. A good tire tech can tell visually or by feel without taking it apart, but that's few and far today.
Of course the tire was damaged; a nail was stuck in it, and it's going to get worse when I jam a lubed up reamer in there and twist it around.![]()
I do if they haven't been driven on very far.We don't fix run flats. You are buying a new tire if you have a run flat or you can fix it yourself.
I know that. I was just being sarcastic.Internal damage. They come apart when driven on low air. There will be a powder inside of it. You can usually sign a line around the sidewalk
I do if they haven't been driven on very far.![]()
I only fix my own nowadays and no I don't toss good tires because there is a plug in it.Not worth the chance these days. If you're going to whine about it you shouldn't have brought a car that requires run flats. Sorry you're $80k BMW needs a $400 tire![]()
Don't patch. Plug. This is your brand:
Done.
