Tire plug kit
thefoobag
buddy just got a few at dollar general for like 2-3 dollars, we plug ours as well as friends tires with no issues using them as long as its done properly.
PureLeaf
From what I've seen in regards to plug tools, it seems like its 1 company that makes them for just about everyone...
SMKS
USA, planet Earth
Safety Seal are the ones I like.
However, remember that tire plugs aren't the best type of tire repair and the RMA (the trade group for tire manufacturers) says they shouldn't be used. They only say combination patch/plugs are allowed. The most common ones look like this:
LEVE
On the Willapa
Humm... I just used one yesterday to patch two holes on my wife's car's tire. It was the Slime Delux Plug Kit #20302. It came with a couple of good tools and enough plugs and cement to spare.
bwringer
Indianapolis
Nealey. Quite simply the best option for repairing a tubeless tire from the outside.
http://www.tirerepairkit.com/
These things are freakin' awesome. Basically, they're a little thinner than the usual gummy worm, and you install them differently so you end up with four cords in the hole, plus a knot on the inside to make sure it can't come out. No added glue needed, either.
Crazyjake8493
Upstate NY
I've used the Slime kit a few times and never had a problem. Patched a tire on my dually a few years ago after I pulled a 10d nail out of it. Went another 18 months before I sold the truck, never lost air. 6 months ago I pulled a roofing nail out of the tire on my durango and patched it with another plug from the same kit, hasn't leaked at all since the repair.
SMKS
USA, planet Earth
I've never seen a plug "come out." Poor installation or other problems can cause them to leak, but I've never seen one come out. I used to work in a shop that used plugs for some repairs, so I've installed many of them.
Safety Seal also doesn't recommend using glue on their plugs.
AA/FC
I worked at a full service gas station 26 years ago. Plugs were somewhat "acceptable" back then.... I've personally installed hundreds of them over the years. Never had a problem with them.
I have the safety Seal kit linked above from amazon. They've been around for decades and is the kit/brand to buy.
Davefr
OR
Why? I've used plugs many times for small holes like a nail or screw.
If the plug were to fail, all it would do is cause a small leak which TPMS should catch fairly quickly.
I just don't see how a small plug could possibly cause a catastrophic tire failure.
SMKS
USA, planet Earth
I never said anything about a "catastrophic failure."
Although, I've read some people claim plugs can allow air to leak in between the plies -because the inner liner isn't sealed- and promote tread separation. I could possibly see that happening if the tire was starting to fail and the air leakage could make it worse.
Read at the link I posted. They explain their reasoning there.
A couple are:
-sealing both the inner liner and injury path.
-the tire must be removed to inspect the interior for damage, such as damage from running low on pressure.
It's pretty obvious that a patch/plug is a better repair. I own and have used plugs, but I know they aren't the best type of repair.
gtabasso
Cleveland, Ohio
Speaking of which, I just had a nail in my tire. An awesome coworker plugged it for me. He's very handy. Done in 20 minutes.
rlitman
Long Island
I actually like the pistol grip handles on that kit. And the spiral reamer it comes with is acceptable. I keep this kit in the car (the Safetseal kit is in the shop).
Slime also makes a T handle kit where the reamer has a diamond pattern on it. First time I tried it, the diamonds were completely removed when I pushed it through the steel belts. Total trash!
I've included the pictures, for those who are not familiar with the subtle differences that are actually quite significant.
And simply forget about any of the kits that have a screwdriver style handle on the reamer or plugger. Even if you have the hands of Hephaestus, by the time you can manage to get the plug in, the hole is probably reamed too loose to safely plug any more.
allinon72
Indianapolis
Thezapper
Toronto, Ontario
The reason the plugs are a problem is that you don't remove tire from the rim to inspect for damage to the side wall when driven on flat. We do fleet work for large rental car company's and they specifically want a patch from the inside and want a close inspection of the sidewall. Half the time the tires have side wall damage so it gets a new tire anyway. When the bossman abolished the plug, he stopped ordering them and said he didn't want to see any plugging tools in the shop period. So I took the extra patches I had in my box and the tools reemer/driver and put them in my truck for a emergency.
At first I hated doing them (patch) but it does make a better repair, you remove the tire, replace valve stem, clean the rim, balance etc... a perfect tire repair. The plugs are good too, I'm not against them. I think the ones we had were called sure seal? Not sure but they were orange in colour and never had one leak or pop out in 20 years. I even remember using 2/3 for those larger holes lol....
yamaha0343
South Louisiana
I've been using plugs for years, and haven't had one fail. The Slime kits have worked for me, but I'm going to order the Safety Seal based on ya'll's recommendation.
Outlander
Quebec, Canada
I have a kit in my ATV - rocks are killers for the sidewalls. Had to stop and give plugs and some compressor time in the trail again a couple of weekends back. The old "I left my compressor on the workbench" story
T
The thing I like about the "Stop n Go" kit is their plugs are mushroom shaped. I have used them for years on motorcycle tires and never had a problem.
I am surprised that more people have not mention this brand. Maybe because it is marketed toward consumers and motorcycles, but it works fine on cars and pickups.
The plug design looks good
and their "pocket" kit would fit in almost any glove box (need to add a Leatherman for the pliers and knife).
CJM8515
I always carry plugs in my truck and atv. We used to plug peoples tires on the road when towing/service truck. But we always made sure to tell them that the end result was they were temporary. However I cant tell you how many times ive plugged my work trucks or my own or families cars with good results. Never had an issue to date.
SMKS
USA, planet Earth
Well by golly, a trade group interested in selling new tires doesn't recommend that you repair your old tires. Shocked!
You're completely misunderstanding.
If you read what I posted, you'll see they say repairing tires is fine, but plugs aren't fine. Only combination patch/plugs are acceptable.
