barrysuperhawk
I have a Clarke mig130EN that mostly does everything I need*, but it is tired. I don't want to buy a new welder at the moment because, reasons.
My first problem is the ground cable needs to be replaced. It has been damaged, cut and re-crimped enough that it's less than 4 feet now...
My second problem is that the gun is also pretty worn, part of it is held together with electrical tape, and there is some obstruction keeping gas from working, so its currently flux core only. I don't mind flux core, but I would like to try some aluminum, and that requires gas.
So I was thinking I could get these (or something similar)
https://www.amazon.com/YESWELDER-Welding-Replacement-Clarke-Stinger/dp/B07MM13DZ2/ref=sr_1_2?dchild=1&keywords=clarke+welder+130en&qid=1613246427&sr=8-2
https://www.amazon.com/Welding-Ground-Clamp-Lead-Assembly/dp/B07D4153JB/ref=sr_1_3?dchild=1&keywords=welder+ground+clamp+cable&qid=1613251650&sr=8-3
...and renew my welder. Am I on the right track? Particularly, is there anything specific I should look for in a replacement gun, or anything I should stay away from?
* Disclaimer(s): I am not a professional welder, I have not been trained, I do not do any type of fabrication for a living, 3 harbor freight welders gave up their lives for me to obtain the knowledge I have. I only have 110 in my garage and while I would like 220, however I have MANY other home improvements that take priority. I don't like throwing things away when they are fixable.. I know my welder isn't red, or even the right shade of blue, but its what I have.
