To plane or not to plane ?
Johnny Generic
35 miles NE of Pittsburgh, Pa.
Situation,
I have a deck ( 5/8" ) 24' x 24' plus a 10' x10' extension and approximal 50' of walk way 2"x. All wood is prs treated and about 25 years old. All wood needs " freshened up ".Thinking about buying a planner to remove / resurface a few 16ths or 32nds vs replacing wood. Would have no use for planner after use. Lumber prices out of this world.
Thoughts, suggestions, ideas. Thanks a head for your replies. JOHNNY GENERIC
CraigStu
Blacksburg, Va
Sander instead of a planer? I have a hand held planer and find I need to be real careful about the direction of the grain because I find the planer blade can pick it up and snap it off when it's in the wrong orientation. Or power wash and use Behr DeckOver paint.
Renegade1LI
long island ny
I think your biggest problem will be the nails, how close to the surface are they? Are protruding? Sander or planer will not play well with nail heads, power washing & scrubbing will be your best bet. Even if their are no fasteners protruding it's still hard to sand if the boards are slightly cupped & you can't sand the edges which are typically rounded over.
Mark_17
If trying to extend the life, see if flipping the boards would work for you.
K'ledgeBldr
Johns Creek, GA
There are wood “brighteners” on the market that you use in conjunction with pressure washing.
No Sanding, planing, required! Nails and screws would be your demise- and the tool’s!
couch67
Ontario Canada
Rent a walk behind floor sander, the vibrating kind (not the drum). Used one on my 15 year old cedar deck last year. 16x16, took 2 hours total. Looked new after!
jshillin
PA
Pressure wash the deck, then make sure all nails are slightly below the surface and follow up with a floor sander when it's dry.
Kaizen
New England
The winner.
Unless this is mahogany or such just flip and stain. If expensive wood maybe a handheld sander and lots of beer. Big sanders won’t work well as the boards are cupped so you need to finesse a sander to reach.
Slednut
Washington state
The winner.
After 25 years the deck boards will have such deep stains on the bottom from the joists it would look bad.
This deck was 30 years old the last time I used a rectangular floor sander on it. It took about an hour.
When I was younger I use to take each board up, belt sand it and put the boards back. One time I even rounded the edges with a router before reinstalling them.
It would take hours.
Meursault74
Southern California
no suggestions for your project, but did anyone else think of this when they saw the subject matter of this thread?
Renegade1LI
long island ny
I have heard of people flipping the boards with no issues but I think it's more like a big foot sighting. Any deck that I've seen come up the boards never looked good, remember the good side was chosen to face up to start. Pressure wash, scrub & treat it will look good.
Kaizen
New England
All true. Thanks for pointing that out. I figured he would dark stain so not an issue. Flipping is a money saver but will take work.
HenryAZ
MEMBER EMERITUS
South Congress AZ
The grime embedded in deck wood will play heck with a planer's cutters, dulling them quickly. If you really want to go the planer route, at least pressure wash the deck thoroughly before planing.
toolmiser
La Crosse, WI
You didn't describe the current surface. Is it peeling, degraded from lack of maintenance, etc. There may be better ways of improving it.
I had made the mistake of using solid color stain a couple times. I had to "strip it" and then I went back to semi solid stain and it's held up good for 6 more years.
Showkey
"MEMBER EMERITUS"
Wausau WI
If you were to renew the wood surface that is worn, cupped and rough.........remove each board. Then either surface plane or surface sand each board. Then stain and seal with you favorite product ......which is another topic.
None of this is easy and involves hours and hours of work. If cost and work is an issue ......remember each 14’ deck board is about $40 at current pricing. So 24’ deck length is two pieces might be $60. Just the deck boards not the walk way would be $2500 in materials ???? +/- 20%.
Yes, the Planer blades will take a beating. Cleaner the boards ( less dirt the beter) Typical surface planer:
Floor sander will NOT work on cupped warped decking plus there still the fastener issue.
