To POWDER or Paint my Caliper
mobiledynamics
Gotham City
8 Pot Brembo needs a rebuild.
I had my mind set on sending them to the PC.
Brembo uses Paint.
Paint is also less of a ~heat~ insulator compared to Powder.
Thoughts ?
I have had calipers painted in the past. After 6 hrs +, they have held up . Pro Price...Pro Quality.
Ehh. I'm 2nd guessing it and thinking I should go back to paint
mobiledynamics
Gotham City
6-10 hrs on 90 degree temps is more than hot enough.
I'm sure there are various *paints* out there...
Not sure if you saw my other thread...but my paint shop is asking 1K to do them....
G1GRANDEUR
Powder coating is not recommend for tacked cars due to the fact that powder coating acts as an insulator and will retain more heat over a painted finish. This is why many high end vehicles brake calipers are painted.
Use g2 or VHT.
mobiledynamics
Gotham City
Understood on the insulator...
PC is thicker - hence the insulator
For this application, it's my daily driver.
The math as well is more reasonable going PC route.
About 1/2 the costs..
5mall5nail5
Bucks County, PA
Use g2 or VHT.
Such a vague misnomer in fact many calipers like Brembo have a baked on base/primer coat!
Many powder coats are metallic and transfer heat. There's no blanket statement.
If powder coat was not advised on tracked cars why would every single Wilwood caliper come powder coated? They're specifically for aftermarket/track car applications.
G1GRANDEUR
ask wilwood, Brembo does not recommend using powder coating.
but yes, not all the powder coatings are same.
5mall5nail5
Bucks County, PA
Again, brembo doesn't recommend using powder coat because then you won't send your calipers to them for a $750 rebuild. I do powder coating myself and my buddy runs a pretty high volume shop - we've both done toooons of brembo calipers without issue.
zakmartin
Seattle, WA
I wonder if anyone's ever used those ebay adhesive fake Brembo facias to make their real Brembos look nice and clean.
Engineer61
Colorado
Think about the powder coating process - plastic powder is sprayed on, the part is put into an oven and the powder is heated so it goes semi-liquid and smooths out to coat the part, oven turned off and the part cooled to re-solidify the plastic coating.
Now think about your calipers - brakes are applied repeatedly; rotor heats up, maybe to red hot (look at road race cars, on some tracks the rotors are glowing so you can see them at night); caliper heats up, powder coating heats up and melts and every bit of sand etc that hits the caliper starts to stick. Car is parked, caliper cools down and the plastic coating retains all of that crud forever more.
Real bad idea to put powder coating on anything that gets hot (250-300+ F).
