I've got a 2 car detached GA with an open attic (gable roof). When I built it years ago I stapled fiberglass in the roof rafters. Then I put up that aluminum clad 4x8 1/2" foam sheeting. It was easy to lift up into the attic area and of course to cut/size and it helped brighten up the GA with a reflective surface.
Before putting the insulation up in the rafters I put boards across the openings into the soffit area but I also drilled large holes in the boards and stapled screen material across each hole. When installing the soffit boards I also put in soffit vents. They are not continuous soffit vents - I just put in 3 foot strip and left about 2 feet or so between...
The point is there is an open area in the soffit cavity and there are vent holes from there to each roof rafter 'channel'. Now that channel is largely 'filled in' with fiberglass batting though I suspect some degree of air could pass thru the fiberglass and/or any small space between the fiberglass and the roof decking. The attic space itself - while open to the GA space below - is sealed from the soffits/raffters.
But the ridge of the the roof is *NOT* vented. I'm facing a new shingling job soon. When I painted last year I noticed a little mold here and there around the ridge vents. It's somewhat humid, hot summers, rarely freezes.
Vent? Or keep the ridge capped?
Thanks!
Thanks!
