Today's junkyard find
mark-NJ
new jersey
That's an old King-Seeley from the very late '50s, sold under contract to Sears. Decent machine & pretty robust. I know a couple of people who have changed the pulley ratio to slow it down for metal cutting...with very satisfactory results.
I have the '40s-era forerunner 103.0103
neophyte
Pennsylvannia
Im curious.. anyone know the deal with the short/stubby BS from back then under the same names?
It’s likely a three wheel bandsaw.
Running the blade around three wheels gives a much deeper throat depth, allowing for wide cuts for wide pattern cutting (like signs, or flats for theater sets.)
The major drawback with three wheel bandsaws is blade tracking, which is more difficult, and the fact that the blades run over small diameter wheel, resulting in the blades fatiguing and breaking quicker.
Three wheel bandsaws are usually smaller, lighter, and therefore more easily moved or transported than two wheel bandsaws with the same throat depth, so preferable in a home shop with limited space.
skeer
Standish, MI Area
Was unaware of most of that.. thanks!
Usual usage is cutting thin stuff, and soft stuff, like pine, in 1/2" or so sizes, for templates, ornaments, etc. Many will struggle, throw blades, cut crooked, etc, if you try to cut 2" thick ipe or oak. Buddy had one, was so grateful to upgrade to a 14" two wheel.
skeer
Standish, MI Area
Wanted to ask.. while I am sifting through the many.. MANY knob offerings on Amazon. In the off chance someone here has a good knob source for this bandsaw (or related equipment)? Originals are just too damn pricey online.
Cruzan80
Denver, CO
I would check OWWM and BOYD. Overall, it should be a standard threading, so if appearance doesn't matter, just go to Ace Hardware.
Jarhead0408
Who knows?
Are they on here? If so I’ll do a search since I have the same bandsaw.
mark-NJ
new jersey
Is who / what "on here"?
Are you asking about the people I referenced who are running these saws slower? One was a machine ship I frequented years back and the other was a guy I met & befriended after a CL deal. Neither are members of GJ as far as I know.
Firebrick43
West central Indiana
I had one of those aluminum’s frame craftsman bandsaws given to me years ago. It was quickly given away again as it couldn’t tension a blade properly except for little tiny ones for doing scroll work and such (3/16”). The frame just wasn’t stiff enough.
  • Like
Reactions: RTM
Jarhead0408
Who knows?
Yes, I was asking whether those individuals were here on the GarageJournal. 10-4 on the response. Thanks.
