Toggle over load retention, trailer devices?
andyvh1959
Green Bay WI
I am looking for a device that makes retaining a repeatable load in a trailer a consistent and quick easy action. The chorale group I am in has a large van trailer to transport our performance risers. In the trailer we use D-rings in the floor, to which we use large caribiners and turnbuckle devices to retain the risers (which are on casters). But the turnbuckles have to be properly cranked to put the caribiner and turnbuckle into a loaded condition to adequately keep the risers from moving around. When folded up for transport, each four step riser section is about 85" long, 30" wide and 60" high.
I may check Grainger, McMaster-Carr or perhaps even a marine supplier for a cam over toggle device that once properly preset, we connect the large caribiner to the D-ring on one end of the riser section, then connect the other end to the D-ring and simply swing the toggle clamp over to apply the right retention onto the riser section. I may also install low profile steel recessed pockets on the trailer floor for the 4" casters to set into. Ideas anyone?
A
andyvh1959
Green Bay WI
McMaster Carr has these load binders, rated at 370 lbs each which should be good for our application:
But I'd prefer more of a hook shape at each end of the device.
Firebrick43
West central Indiana
Are you against ratchet straps?
Etrack can be put on the floor or side and short e track tie off rings hooked to the carabiners in the front and a single e track ratchet strap in the back? They even make retractable e track straps which make managing the tails easy
over center binders are always a pain in the rear and can be unsafe if not properly tension coming loose. For chain my father and I only trust the ratcheting ones like wssix99 showed
jack stand
Lakes Region Maine
I imagine that you're not using chains, and the trouble with your idea is a static length tie down/over center binder would only work with the right load/cargo dimensions. I'm envisioned several stacks that probably are not the same dimension.
Ratchet straps - good one's, are the way to go. I've gotten some nice "little ones" with a heavy 1' strap and a heavy duty ratchet assembly, ordered to length and the desired attachment ends (hook, t-wall, hook & ring,etc) from ratchet straps USA
Quick, easy and versatile. 👍
finn
The UP, God's country
Look for trailer tie downs used to retain the transom of a small boat to a trailer. They are adjustable straps with hooks on both ends and an over center cam device.
Look up “Transom straps”. There are dozens of different brands, and they’re stronger and less hassle than normal cheesy ratchet straps,mand easier on your equipment than clunky traditional load binders, since they’re webbing, like seat belt material.
A
andyvh1959
Green Bay WI
Good points about the ratchet strap idea versus the load binders. We most often load our riser trailer after a concert, while wearing our Tux gear, so quick, easy, positive access and secure loading is key. I'll have to find a ratchet strap type that does not require a lot of handling to use.
firebirdparts
Kingsport, TN
turnbuckles are terrible slow, you're right. You could look around for ultra-light-duty chain binders and then ideally match that up with a strap of some sort that is the perfect length.
I'm not sure what these are intended for, but these are the lightest ones I've ever seen:
Of course you could make something no more complex than that.
A
andyvh1959
Green Bay WI
This is us, the longest running continuous male chorus in the upper midwest: https://macdowellchorus.com/
Not Barbershop. We're about 60 members performing now, was close to 100 when I joined back in 1992.
Now into our 91st concert season, my 33rd year with the chorus.
Challenge with the load straps is they need to be fairly short overall, like less than 12" long hook to hook. I may have found another option; a transom cam over strap for a boat strap onto a trailer. Its like a lashing strap, but with a cam over handle to load the strap rather than just pull on the loose end. I may be able to shorten the overall length to allow just enough to connect to the hook on the riser frame and to the D-ring on the trailer floor, then just lever over the handle to load the strap. If I move the hook on the riser frame I can allow for a longer overal strap length.
1745003506385.pngThese show on Google as available at Meijer for $14 a pair. Hook each end onto the D-ring and riser frame, pull the strap through and lever over the handle. Then a Velcro strap holds the leverin position.
