48willys
How do I shim a toilet on my polished concrete floor?
I would recommend the plastic shims over the wooden ones. If moisture builds up under the toilet, the wood ones could rot.
FYI- Our local code requires the toilet be caulked all the way around at the floor. Your mileage may vary!
set the bowl dry and mark around the base with a pencil. lift the bowl ,prepare the wax seal and bolts . now mix up some plaster of paris and drop it inside the mark set the bowl and level it as you tighten. clean the excess plaster with a wet sponge and let it dry . the toilet will never move now
