Toilet question...seriously.
Copperbobber
Mid Michigan
I just changed the tank on the back of the stool about a month ago, and evertime I hit the handle it'll flush great but the bowl will NOT refill. I have to wait and hold the handle down by hand to refill it. Any body ever had this problem? Did I forget something here? It's driving me crazy.
Paradise Ridge
North Idaho
Did you stick the little rubber hose back into the top of the round tube that comes up from the bottom ? It's the tube that the rubber stopper is usually mounted to.
Scott
Edit:
in the pic it's the bowl re-fill tube.
The Money Pit
Virginia
I replaced my flapper once and didn't cut the chain short enough and it was catching under the flapper and caused it to run every 5 minutes or so. I snipped it shorter and viola! Problem fixed.
C
Copperbobber
Mid Michigan
When I flush, water runs out of the little bowl fill tube into the bigger overflow tube but nothing gets to the bowl. The tank was supposed to be a bolt on deal, or so I thought.
