Toilets
bluedog225
Texas
I’ve started shopping for toilets for the workshop. It’s a small functional bathroom. And I need a small, white, round toilet. The research gets a little mind numbing.
It’ll just be me out there, and occasionally the wife. I’m on acreage and generally won’t come inside to piss. I’ll probably use it once or twice a day. So I don’t really give a darn about gallons per flush.
What’s a solid reliable go-to brand? What’s the difference between the $500 toilets that look pretty similar to the $120 toilets? I don’t get it.
I just want once and done. No fancy dual flush, super low flow, etc. Just your basic, competent, made in USA toilet.
Thanks
wssix99
Chicago, IL
The best toilet I ever had was the temporary special purchase Eljer we got from Menards as a temporary unit while we lived in and were building our house. I think it was similar to this one: http://m.eljer.com/products/product_detail.aspx?id=2563
BTW - Treat yourself. Go elongated and comfort height. Your colon will thank you 10 years from now, even if you don't think you need these features...
The Eljer features a large surface area of water. This allows it to take man-size **** and not get dirty. You can go a long time without needing to scrub these.
We switched over to fancy $600 Toto toilets in the house and I hate them. They have a small pool at the bottom so craps poke out the top. During a sit, the place smells like an outhouse and the skid marks need to be cleaned several times a week. ...I really miss my Eljer.
ddurrett896
VA
Just put one of these in my garage and like it. Skirted so it's easy to clean and I like the ReadyLock system that sets and secures the wax ring, making it easy to drop the toiler and tighten.
bluedog225
Texas
Thanks. Will check it out.
I’ve got one of each (round and elongated) at home. I hated the small round one at first. Now, 15 years later, it’s fine. I just don’t spend much time there.
The skirted (I didn’t know that term) would be great. I hate getting on my knees to clean all the sculpted surfaces on most of them. And anything that makes the install easier would be good. Getting a little old to be setting toilets.
Gong down that trail, the one piece skirted look even better. Biggest deal for me is traditional insides so I can repair easily.
housewolf
East Texas
You’ll find less piss on the floor in front of the toilet with elongated. 18” height is the way to go too. I think the price is same for the taller bowls.
The skirted ones are nice (it’s what I have in my house) the price goes up with them though
Kohler & American Standard both make a budget friendly high quality toilet. You won’t likely find one that is more than 1.6 gpf
BigGarage
Just south of Detroit, MI.
Thanks
BigGarage
If you are "on acreage" how far will the toilet be from getting waste to the main drain line? You can pick up older, used, large-tank toilets that still have the high flow set-up. Check out a resale shop where they salvage items from demolished homes.
I have a very old toilet in my garage bathroom and it has the large water tank. It makes the toilet look small.
I put a tall & elongated toilet in my 2nd floor 1/2 bath. It's got the 1.6 gal. tank I believe. If I'm having a sitdown on it I run the water on the sink to help it flush out since it has a way to go. I love the elongated and taller features. You'll never regret it.
Dennis
bluedog225
Texas
That’s an interesting thought. A big, 70’s deal. What were they? 7 gallons a flush? Like a 454 Chevy.
The drain is immediately down to the holding tank and septic field.
gleman
Michigan And Florida too!
Dennis
A urinal in the house, very nice!
Glemon
NE
The taller is really a no brainier, feels funny at first, but you quickly get used to it. The extra height makes it easier to get up and down off the throne, better when you get older. Last I shopped a few years ago tall was pretty much standard and standard height was hard to find.
We have approx. $200 (once again few years back, at the time the cheapest toilets you could get were a hundred or so) Kohlers in our old house and now in our new. They do everything they need to do reliably.
dcg9381
Austin, TX
I didn’t know they made them taller. That would be good. Thanks.
This. They make them taller and longer. Do both. Worth it. You won't go back.
Flush gallons seems to be regulated, so you're not getting much product difference in toilets other than valve type... Unless you move up to some sort of pressure assist system.
engineer2
Chicago burbs
American Standard Champion is good and available everywhere. Even when the kids were teens they had a hard time clogging it.
A step up would be the Toto brand.
flippin
Montreal - Ottawa
Not sure if there' a difference in what's available in Canada, but every plumber seems to recommend the Cadet Pro from American Standard. This is based exclusively on two things (1) the design of the of the porcelain and how all of the rubber bits and pieces marry up to form perfect seals (2) fluid design of the internal plumbing to minimize impedance in the interests of smooth flow, and zero clogs ;)
ycgoat
S.E. Va
I second engineer2 above with
I installed these when my boys were young around 20 years ago and now am raising a grandson; I have not unclogged a toilet in the house since.
billconner
Thousand Islands NYS
Definitely a one piece casting for the bowl. The least expensive are cast in halves and joined before firing. They never flush or clean as well and some not quite round and don't plunge easily.
Personally, I like Toto brand. So have the plumbers I've used. Both kept them in stock. Flush well and clean well.
Joemctag
Outside raleigh nc
A liquid falling from a height causes tiny droplets to land outside the toilet. Sitting down to pee IS possible.
Just sayin’.
Gutman
ENC
" man-size ****... and ...the skid marks"
A good name for a band.
WSSIX99, I'll buy you a beer!
dcg9381
Austin, TX
Without going into too much detail, this is a common problem in my household. I have a "tall" toilet, not a long toilet. My spouse is accusing me of having "issues" but the reality is that her *** is simply shaped a lot different than mine (as well it should be).
I don't pee in the house. This has solved all the other issues. :)
housewolf
East Texas
What are the round access hatches for?
I don’t know what brand that is but Kohler has a device that bolts to the flange and fits below the toilet on the skirted models. The china fastens to this device via holes in the skirt. I’ve set several of them and was skeptical but they work pretty good. I can’t stand a “rocking” toilet, a toilet should feel like it’s bonded to the floor
Red 17
Pasadena CA
Just swapped out two small rounds to Kohler Highline Arc "Four wheel drive long bed" toilets.
They are 1.2 gallon I think but they have valve that dumps all the water at once. Seems to work fine.
Looked at all the toilets named so far above--all would work fine.
AffableCurmudgeon
Triad Area NC
I replaced all 4 toilets in the house with Delta elongated chair height ones last year when we moved here. These have the 3 inch flappers. That is a little weird at first as all the water rushes out quickly, but in almost a year that we have lived here, not a single clog.
Norcal
You want a Flush Mor Crapmaster, but seriously a Kohler Wellworth is a pretty good flush.
SBAG
I need a his and hers. I’m 6’ and she’s 4’10” (95 lbs of pure Korean gochujang).
MushCreek
Upstate South Carolina
We have 4 toilets on our property- one fancy Kohler, and three Glacier Bay cheapo's from HD. In eleven years, I've only repaired one- the Kohler. The Glacier Bay ones are the raised, extended bowl ones- still around $100. None of them have ever clogged or failed to flush. I do prefer a soft-close seat so it doesn't slam if I fumble putting it down.
tez929rr
Welfare, TX
Put two 99 dollar HD brand toilets in our steel building apartment and they have been perfect for 7 years now, never need a second flush.
