Tone Generator w/Amplifier Kit
FatFndr
oHIo
I need to locate some (disconnected) telephone cables and speaker wires in my home. The wires go into the attic and disappear under blown-in insulation, a tone generator would be of valuable help. I have checked, Amazon, Home Depot, Lowes, Menards, Northern tool, Grainger, Harbor Freight and Sears (outa' sight prices at Sears). I don't need a fancy one, just one that works easily and correctly. Amazon is running ahead of the pack with a XTec Instruments 40180 for $70, but the reviews aren't very good overall saying there is cross talk/static, you need to be within 1" of cable to hear, plus the tone is hard to hear and you need ear buds.
Does anyone know of a reliable, easy to use/hear that falls in the $50-100 (or less) range? Is it possible to make one? this will be for home use only.
bry@n
Ocean County, NJ
I have a set you can use. I forgot about this. Send me a pm on Saturday and I'll try to get you something to use.
F
FatFndr
oHIo
Ordered a Fluke Pro 3000, Amazon $69.99 shipping paid, specs say it can penetrate a framed wall 1 to 1.5 feet. Just what I need and the price isn't out of sight for a homeowner..........I have a lot of cables to ring out.
Metal-Marc
Foothills of the Adirondacks
Been using this combo for years without any issues.
RedBKM
Central Virginia
I've always used the Triplett Fox and Hound series. My original blue F&H is still working but the newer Hotwire version works on live AC up to 240V.
I don't think you can go wrong with the Fluke 3000 either.
ratdoggy
Akron-Canton area OH
Could someone explain why you need one and how to use one please? I understand it helps you trace wires but don't know more than that.
F
FatFndr
oHIo
Received my Fluke Pro 3000 yesterday, threw 2 9v batteries in (batteries not included), read the instructions (simple) and found the other end of the wire I was looking for within 15 minutes. This after nearly an hour of struggling hand tracing the phone cable through the blown in insulation attic in the winter. Got a reading right through not only the walls but the ceiling as well. Found 2 more terminated cables as well that I had been searching for, back at it today, have 3 more to go. I should have got one of these a long time ago.
Tyberius
Wilmette, IL
that's pretty much it. But if you've got more than one set of wires they are handy.
You clamp the alligators on the block or plug the rj11 connector into the port and flip the switch to the tone you want. You sniff the possible other end until you hear the tone. You can also use the above Progressive to test the tip/ring setup and whether the line itself is active from the telco.
I've seen boxes where the phone service tech will write notes to the next guy in there to "watch for rats" and "lookout!" and the mess inside is years and years of different telcos, building managers, tenants, and rats changing the wiring.
I've got two tone generators, one like the above Progressive, and one in my wire mapper. I can get the job done with two, but for some stuff like the rat's nests, a couple more wouldn't go unused.
ratdoggy
So basically you can hook up a power supply to wires in the basement and see if it's live on the second floor, for alarm wiring, phone and electric?
jeffmoss26
Cleveland, Ohio
It's not a power supply. It literally sends a tone through the wire which you pick up on the other end.
For example, I have hundreds of pairs of phone wiring in my building. The phone jack in a cubicle may or may not be labeled. When I need to move a phone, I put my toner in the jack, then go back to the wiring closet and use the tone probe to locate the cable.
DenisG
Milwaukee
You hook up the "transmitter" to the wire that you want to trace. It turns the wire into a small antenna that broadcasts a tone signal. When you move the "receiver" part of the set near the wire with the signal, it picks up the tone more loudly than the wires next to it. As others have said, it allows you to find and identify unknown or abandoned wires throughout your building.
