Tongue & Groove-No Router Table?
MattGarage
So Cal
Will need a way to stabilize and may not be able to take the whole pass at once. Successive passes with increasing depth? Sounds like a pretty thin arrangement that may not give needed strength. Can sometimes buy individual bits for the price of an inexpensive set or so. HF has a set that includes a 1/4 bit but the quality of that set is low end and can cause damage. Would be better to buy a $10 carbide bit.
Lumpy102
Ontario Canada
Wow half inch cedar? pretty delicate. do you have a table saw? I'd try cutting the tongue and groove with my tablesaw if I didn't have a good router table and a fine bit. With a quarter inch groove you'd only have an eighth left on either side and that would make for pretty delicate edges. I think dividing the half inch board in thirds would leave a bit more robust edges. just my thoughts
Roert42
NE Penn
Table saw works good for tonged and groove, but can be labor intensive if doing a bunch. If you have a big enough table saw you can use a dado blade, makes it a bit easier. However, for a thinner board, your kerf may be thick enough you might not have to do a bunch of extra work.
mike93lx
Richmond, VA
If it's just for a color check, why bother with the joinery? **** joints and face nails will be a lot easier and faster
strutaeng
Dallas, TX
What tools do you have? Does it have to be T&G?
I was thinking v groove (chamfer on each board) with biscuits. You probably don't have a biscuit joiner, do you?
Half lap is another option with a rabbeting cutter.
You should be able to find cutters that you can cut the groove, the adjust the height and plow out the tongue (flipping the board over.)
In the old days there were pretty inexpensive Stanley metal planes that did T&G. A few years ago you could even find those planes pretty cheap, just sharpen/hone the iron.
R
Richard D
Texas City, between Houston and Galveston
I think I will just **** them together as mentioned. It's just a 36"x48" section of the wall between the front door and a window, to see if I like it. Cedar fence pickets sanded and wiped with boiled linseed oil. Should be quick cheap and easy. Budget is pretty tight.
tarbellb
Oregon
Mount your router (upside down) into a temporary table top. Plunge a zero clearance hole through, clamp a fence for your gap.
Ohmthis
Outside of Louisville KY
A half lap joint will give you what you want here.
This is an example of a homemade jig that can easily be made to use your hand router with. You probably have enough scraps to make a jig that will work. Hope this helps.
