I have been working on the 16*x16* shed, OSB ceiling and lights. I previously had one 4' two tube fluorescent fixture which was terribly inadequate both in lumens and light distribution. I hung OSB, painted it semi gloss white, and installed 7x 4' two tube fixture with 2080 lumen LED T8 style tubes. I got them installed earlier tonight and wow, it is bright. My initial impression is too bright, it's just so much light.
I was going to wire them so half of each fixture came on using two switches for half or full brightness. The fixtures I got have both sockets prewired with a short wire between them, so I wired them every other fixture on each of two switches to simplify the wiring. One switch controls three lights, the other controls four. Three fixtures seems comfortable in overall light but a bit shadowy. I have one more fixture but have to move a shelf to install it. It's a bit shadowy toward that corner so another fixture would be nice in that regard, but maybe too bright with these bulbs.
I used 2080 lumen bulbs because they were cheapest. I have 2200 lumen tubes in the same fixtures in my garage and they're great. Most of my garage lights are at 10' height, whereas the shed is slightly under 8'.
What do you guys think is too much light? This works out to 114 lumens per sq/ft, 130 lumens per sq/ft if I add the last fixture. Should I leave it as is? Get tubes with fewer lumens?
