How is this for fukkinoff? The more we worked on these carts the worse they got, it has been some mystery trouble shooting along the way when we had repeated problems and when they are a mess there is no better way than to strip our custom bodies off, clean them up as seasonal PM.
It involves a little process similar maybe to r&r an engine body similar to a nascar, maybe a drag car. These little suckers are fussy, I still found things I overlooked but part of the deal is a system thinking thing with the mechanic. It really needs a dealer level course but as part of it there is a confusing nut bolt set up. I have tried everything and finally came up with 3 stages stacked in used coffee cups, install in exact reverse order, about 10 bolts in each cup to account for it all as it goes. We will reduce some washers even along the way.
Sorting thru all the bolts is a real problem, egg carton method is not right. Here in theory the mechanic should be able to dump a set of bolts/nuts and he is done with a step when all is used up, move on to next step with cup etc. Here we have a lot of stuff, its easy to keep reaching over getting a bunch of stuff out but with a little work a guy can get about 8 predictable tools, air ratchet etc and deliberately following an experienced pattern it can become fast and correct, twice as good in half the time.
As important as having tools is putting away ones you got in error at the same time you get the correct one, its bigger than being perfectly organized, the discipline to return it quickly and to not get it out the next time its done. The second time I get rid of about half the tools it took me to do it the first time.
