Tool box shocks
ron in sc
Charleston, SC
Need two tool box shocks for a 42" wide CSPS box.
Anyone know where I could get these items. Not shocks for car liftgate.
Brownsfan
Cleveland Ohio
Check with your local truck cap retailer. The rear window shocks come in all shapes and sizes. A lot less heavy duty than a car trunk shock
colin39
Google the numbers on the side of the shock most end in nm the newron meter is the weight that it lifts, hope this helps
larry_g
oregon
You are looking for "Gas Springs" not shocks Search on the correct term and you will find lots of vendors. As said most have numbers on them and I get mine from McMaster Carr.
http://www.mcmaster.com/#gas-springs/=14d88od If you look around McMaster you will also find all the ends and stuff that customize the basic spring.
lg
no neat sig line
Bryanthegreat
Minnesota
I have used a place called Austin Hardware to get replacements. They have a website and you can find a pair that will work.
