Tool cabinets? Which ones
Bennylava
Cleburne, TX
I have some larger tools I need to store, and I'd like to get them off my shelves and into some type of cabinets. Things such as the large craftsman electric angle grinder, a Sawzall, a belt sander, a DA sander, a fairly large buffer, a heat gun, the list goes on. I've got all these big tools and they don't fit in the tool box.
But I'm a something of a noob to garage/shop outfitting. It doesn't seem like I should be going with one of those tool boxes that has a lot of cabinet drawers for this. At the same time, I'm not sure I want those tall locker looking things either. What type of cabinet/s should I go with?
astroracer
Mid_Michigan
This a Craftsman Power Box bolted to the top of a horizontal filing cabinet.
The filing cabinets have tons of storage and they are cheap on CL or garage sales. I paid 10 bucks for this one.
Now, granted, they aren't as heavy duty as the high cost tool boxes but all they have to do is store some tools and they are definitly cheaper.
Mark
jeepinerdeep
South Central PA
peterblock
Eugene Oregon
I like the idea of something like this: http://www.harborfreight.com/tool-storage/all-other-storage/hanging-tool-cabinet-39213.html
I am moving into a really small shop and was thinking of building something like those but without locks and using pegboard inside. The problem I see with those is that they are all keyed and if you lock them and keep the key in the cylinder, then have the key fall out, you are going to have to ruin something to get into your cabinet.
JonnyMac
Victoria, Australia
I quite like the full height 2 door cabinet for items like you mention. Heavy duty all metal versions are what you should be looking for. I cant remember a brand currently but i seem to recall that in jack olsens awsome set up he has one of the most desirable brands and got them on Craigslist...
Bennylava
Cleburne, TX
Well I don't really mind the lockers (i think that type is what you are referring to) but I'm trying to save space.
I might have to do like one member said and put some drawers on the underside of the work bench. But it occurs to me that making a recommendation is going to be difficult without pics of the building itself. So here are a few pics, its just a standalone metal building. Keep in mind the whole thing is a big work in progress. Its currently very far from its final state.
The building is 26'x26' and that shelving at the back, and along the top, was all there when I bought the place. I'll probably be leaving the stuff at the top, cause its pretty good storage. But those shelves at the back might go... I'm not sure. As you can see, they are fine for storage, but they look pretty bad with all my stuff sitting on them. I'd like to have things looking a lot more tidy. And I'll be getting a storage building later on, for the stuff you see that doesn't really go in a garage. So hopefully this description helps with recommendations.
MushCreek
Upstate South Carolina
I'm planning to build custom cabinets, more like kitchen cabinets than shop cabinets. They will mostly be drawers, so there should be tons of storage. I just finished building the cabinets in our kitchen, and our small-ish kitchen has 33 drawers! You really don't sit all that often at a bench. and you don't need a number of places to sit; just one or two. All of the rest of that space under the benches is wasted.
astroracer
Mid_Michigan
Besides the horizontal filing cabinets keep an eye out for old kitchen and bath cabinets. I have a number of these in the shop that I have put on casters. With a piece of steel on top they make excellant grinding and welding stations and, with the casters, they pretty much roll to where ever you need to work. Everything related to their purpose stores in the cabinets and drawers.
This one was trash picked and rebuilt. It did NOT look like this when I picked up by the side of the road...
Really, all you need to do is keep your mind open. :)
Mark
NUTTSGT
Northern Central Ohio
I think what you need to do is a clean up and organize what you have. Once you get that done, make some doors for the long wood shelving unit. Buy some plywood or OSB, some hinges, knobs, magnet latches and some paint. For probably less that $100 bucks you should be able to do that shelving unit and workbench.
Scout Driver
South Dakota
matt_i
+1 for building some doors on what you have there. Even if simple, painted OSB. Figure out a design for 1 or 2 and then keep duplicating it over and over. Once you get the system down it should go pretty fast.
Bennylava
Cleburne, TX
Well that's the problem I'm running into. It does need to be cleaned up, as I just finished up a car I had in there. But as for reorganizing, I've done it a couple of times already, enough to know I need some cabinets. It might not look like it but I've got it all fairly separated out into categories. Probably hard to tell from pics, but you get the idea. As for the way the pegboard looks, I do have plans to buy more pegboard and rearrange all of that.
I really like the look of that. Might have to get a couple. Thanks for the help all. I also like the idea of old junk kitchen and bathroom cabinets. Didn't think of that. I'll check craigslist.
I'd like to add some drawers to the underside of my homemade workbench. That also sounds like a good idea. I'm afraid I'm not much of a carpenter. What all is involved in adding drawers to an existing wood bench like that?
zkling
Add more shelves as needed to what you have, enclose if you want to. File cabinets are great for bulky items, power tools, fluids.
Bennylava
Cleburne, TX
You guys think there is a classy way to enclose that big shelf at the back? Well, nice looking for a garage anyway. To me it looks like any doors I might make would be... unusually large looking.
Scout Driver
South Dakota
Could you make two doors for each individual section? It would be more work, but it would make for smaller doors.
As for your previous question about building drawers......they are pretty simple to build. You can google any number of ways to construct them, but just building a simple box with a face is as easy as can be. Don't get caught up in thinking you need complicated joints or advanced skills to build a drawer.
Scott
