Tool Cart
todo
Set up a new tool cart. Would like to see some other suggestions too2f754c3c04ccc67c546b897255c903b1.jpg
Sent from my SM-G955U using Tapatalk
Druder
Looks like a very efficient use of the space available. I don't see anything I would do differently or add, if you needed screwdrivers or pry bars it would be as easily as drilling a line of holes as needed.
FigureItOut
Bentonville AR
I like the magnetic rails too. I use something similar actually inside a tool bag, and I'm soon going to be transferring it to a cart somewhat like yours. Take a look at VIM Magrail TL magnetic rails. They're designed to go flat in a drawer and store sockets, but using the socket posts and the "lifters" as dividers, they work absolutely awesome mounted on a vertical surface, for all kinds of tools.
mbshop
visalia ca
What magnetic rails are those ? Not sure the cardboard will last long, need to look for a plastic container to cut to replace that. Reminds me I need to do the same.
Al Borland
Only/main problem I see is no way to secure tools. (Tools that walk away)
T
todo
Great job. You are ready to tackle the hunny-do list now
Mostly used for mowers, motorcycles, Side by sides, and yeah some hunny do tasks.
Mainly what I discovered is that having necessary tools all within sight and easy reach, I actually enjoy again doing some of these mundane tasks. No more endless trips retriving tools from a tool box drawer. I'm actually considering getting a second one. Also I think the fact that its so small and easily positioned right beside where I'm working, allowing to reach any tool right from a rolly seat. Not sure why I never used a cart before but I'm sold now on its effectiveness.
cweidert03
New Castle, IN
Looks very efficient.. I too would do this but it will be a few years as my 2yr old and 5 yr old would make quick work of misplacing things!!
Parrothead
Earth
That’s fantastic and built for your needs. I would probably upgrade the cardboard for some plastic bin. Check the usual places like Walmart, Dollar Tree and if need be look at the Container Store. Other than the cardboard I wouldn’t change anything.
T
todo
wm1tvOluXrnUnJNrN6hs9CkV4BiZ_iuT_1SHe-8azKInt8OKA3-A2zIFiKf3hW2GPit_0H1NGo6kPsOz2XXD6JdsVz7IdPhXxXcMtpdKAdHhWPbSkQ2Q-jAVgBn55IPZ6EPHeEMOTkh6zHEInG3sqiJWhOA3M4sK4Yxe9f7wVDM1OgAqmdhFuzCiLDTG1PZ6gCKGCxkTIeNsOzkffHc8henJdSPU-NyjVW_WQIPqoxNRNb5QosHmqWbDR8wNQVV3gv3Y_WUK9LlNe_i33pFSwKX9ZdZVldu6j5PXBrsOiptmDTWndJIogZx_5A3TlExlaotUjfNgvRmwKmj-lbEUP-AB7XbqOWkHLdSUxNNbU0zFT_js0o3ApYE6nWZoT0I5UgcPYiFFzzeO55KQyfVe6bBiMT3BT_ddnX3bIVwJITdtCVCeoX7-WmFBHD9uZgOvlbYk93claCCGFuU_ogEcyfRzDmgCed97vjHbxjKcQLjuc1lUhZ0qP6niQ_sUMcpU9vBd7ECaYx2lTrwkqh4LumbSMOZ9JEkQgLTscIPuuhrT-W5gOMhm_sUqJLnBNTHskKxgGfL7kXO1S8u0cjZLBRV6sc5jv1vMyyGMwagz=w1560-h759-no
Added a few more things, plus a set of Mountain wrenches to the cart. Man am I impressed with these wrenches. Why didn't I know about these until now?
Lelandwelds
Central Texas
I used to have a tool belt set up for framing and one for electrical work. I had a couple of plastic tackle boxes similar to the Stanley that went with each belt.
Same idea I guess. Maybe ladders are a bit harder with a cart.
